VideoHelp.com Forum
  1. Hi All,
    On the last section of shrink, (when you are choosing you output destination) if I take the tick out of region free and place a tick in the region 2 box, does it actually place a region 2 code into the back-up.
    For instance, if I backed up a region 1 disc but placed region 2 back in when backing-up, would I then be able to play it on a hard coded region 2 player.
    Thanks For Your Time
  2. Member MackemX's Avatar
    that's what it does
    I would just make it multi region so it plays on any player though this may affect some DVD's which need selective IFO's to be made region free after ripping or esle you get playback issues. I know 2COOL posted a workaround with one such issue
    check out SmileyPic if you love using smileys :) (LINKSKI)
  3. Thanks for the info.
    If 2COOL reads this, or knows where the post might be find please let me know.
    Up at the top of this page, do an advanced search for the author 2COOL. It'll show u all the posts he/she has made.
  5. Cheers, only thing is, I typed 2COOL in the search and it gave me every post, including those that mentioned his name inside the post. I shall be here all day.
    Thnaks
  6. Member MackemX's Avatar
    http://forum.doom9.org/showthread.php?s=&threadid=43142
    I'll save you the trouble as it takes me seconds, I was just too lazy before
    this is a direct link to a fix he posted regarding a region issue
    http://forum.doom9.org/showthread.ph...490#post365490
  7. Thanks for your help.
    Have A Good One.
    Cheers
  1. DVD Ripping...DVDShrink, DVD Fab question...
    By nharikrishna in forum DVD Ripping
    Last Post: 28th Feb 2011, 05:08
  2. Question about DVDshrink and lossless copying
    By sasuweh in forum Authoring (DVD)
    Last Post: 5th Oct 2010, 13:08
  3. DvdShrink question?
    By Loader09 in forum DVD Ripping
    Last Post: 13th Nov 2009, 12:10
  4. Replies: 2
    Last Post: 23rd Jan 2009, 19:33
  5. dvdshrink question...
    By cyane30 in forum Newbie / General discussions
    Last Post: 1st Nov 2007, 14:14
