VideoHelp.com Forum
Results 1 to 9 of 9
  1. So, I just bought a new Planar PX212M, a very nice monitor with analog, digital, s-video, and composite video inputs. I run my standalone DVD player into the S-video input and my computer obviously goes into the digital input.
    Well, I'll play a movie on my standalone into the S-video input on the monitor, then I'll watch the .VOB's of that same movie on my computer, which goes digitally into the monitor.
    I can almost swear that the video quality is better on the digital input. This doesn't really make sense, as I would think the standalone DVD>s-video method would produce better quality video. The video that results from the standalone dvd player into the s-video input almost seems blurred at times during scenes with lots of movement.
    Does this have anything to do with the fact that the standalone player is progressive scan? Or is the digital video signal from a graphics card simply higher quality than s-video signals?
    -jesse
    http://www.magnolia-net.com/~jnsb/
    aim: stream41 | yahoo: lieinourpig | jessenewton@gmail.com
  2. Banned
    The S-Video signal is still a 400x400 signal (yeah I know, it's a little different from that, but whatever...)
    The signal from your video card is a 1024x768 or 1280x1024 signal.
    DVD resolution is 720x480.
    Which do YOU think will look better?
    (We're assuming, here, that the software player on the computer is as good as the hardware decoding on your deck...)
    - Gurm
  3. Wait a second. If the resolution of a s-video signal is less than the resolution of the DVD video format, what is the point of s-video, if all it will do is degrade the resulting video quality?
    Am I just not understanding this?
    -jesse
  4. Banned
    Well, S-Video is better than regular composite video. They are both an analogue signal which only carries standard TV-resolution...
    - Gurm
  5. So, on a standalone DVD player that only has composite and s-video outputs, exactly how are you supposed to take advantage of the higher DVD quality?
    -jesse
  6. Banned
    Define "higher DVD quality".
    You're getting a much BETTER 400x400 signal than you would from a VCR, that much is for sure.
    - Gurm
  7. I guess I don't understand why companies would build a DVD player that intentionally sends a 720x480 signal through a 400x400 cable as its "highest" quality output option.
    -jesse
  8. Banned
    Because most people own an output device that is only capable of displaying 400x400? It's called a TV.
    - Gurm
  9. Originally Posted by stream
    -jesse
    Well you SHOULD be using the Component outputs to get the true resolution of the DVD's.
    The other outputs are there because in the overall picture (all Tv's totalled) there are not many TV's that have Component inputs but only S-Video or Composite. Still DVD's will look FAR surperior to VHS or any other inputted signal to a analog TV (with no Component inputs).
  1. Getting the BEST out of my Graphics Card and Monitor
    By SE14man in forum Newbie / General discussions
    Last Post: 27th Dec 2010, 08:42
  2. Why is quality better on TV than monitor with the same video?
    By videohalp in forum Newbie / General discussions
    Last Post: 7th Apr 2009, 21:08
  3. Replies: 11
    Last Post: 9th Nov 2008, 07:34
  4. Replies: 3
    Last Post: 7th Mar 2008, 10:43
  5. Replies: 15
    Last Post: 17th Jun 2007, 03:41
