I wanted to warn potential buyers of the Philips DVDR-77 recorder that it does
not have fast-forward or rewind capability. I know that this seems odd, kinda like
a car that comes without wheels. I hope you do not get stuck with this recorder like I did. Yes, I even confirmed with Philips that the unit cannot do FF/REW.
Argh!
Hi,
This seems odd, i've got a philips dvdr890 and there is no fast forward or reverse buttons on the remote.
But if you you press and hold the Next chapter/title or Previous chapter/title selection buttons for a few seconds they become fast forward or rewind buttons.
the newer recorders might be the same
Are you shure ???
From manual
http://www.p4c.philips.com/files/d/d...17_dfu_aen.pdf
|<< Previous Chapter Track/Reverse search:
Pressing this button once during playback will return to the previous
chapter track/ title
If this button is held down during playback, it will search forward.
If this button is held down during a still picture, it will search backward
in slow motion.
>>| Next title/Chapter/Track/Forward search:
Pressing this button once during playback will jump to the next
chapter/track.
If button is held down during a still picture function, it will search
forward in slow motion.Pinnacle Studio 8 and DV home video editing (ver.9 already home)
The printed manual that I have refers to this method as "scan", which was a "play 10 seconds from the start of each chapter" functionality on previous philips DVD recorders I have used. So now they are using that name to refer to different functionalities.Originally Posted by donpedro
It is also possible to execute fast-forward and rewind thru a menu key sequence. But my point is that this is a very basic function, which should have a dedicated key on the remote. How is the babysitter supposed to know that to fast-forward you have to press-and-hold the chapter-skip key? It is definately not intuitive.
Luckily, the unit does respond to fast-forward and rewind IR codes from the 985 recorders remote that I borrowed. I copied those codes to my MX500 Universal Learning Remote. That copying of codes kept me from drop kicking this recorder out of my window.
Thanks for all the tips guys.
Chris
I understand your concern and I agree with you that it should have separate buttons, but you are over-reacting. Judging DVD Recorder quality based on some two stupid missing buttons on remote ???Originally Posted by chrish
BTW: Scan is still scan. Search is not Scan.Pinnacle Studio 8 and DV home video editing (ver.9 already home)
I fixed my Philips DVDR 3455H dvd/hdd recorder
By dphirschler in forum DVD & Blu-ray RecordersReplies: 48Last Post: 26th Feb 2011, 18:40 -
Philips DVDR-3480 DVD Recorder and Player 1080iâ€
By Vixfoxwatch in forum Newbie / General discussionsReplies: 5Last Post: 7th Nov 2010, 14:18 -
DVD Recorder Philips DVDR 3475/37. Help-me with region free.
By Aurelio in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Sep 2007, 13:04 -
Philips DVDR 3390 - Can I capture to a PC with this recorder?
By muzicman82 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Jul 2007, 17:32 -
Philips DVD 160GB Recorder Model DVDR 3455H
By vsenapati in forum DVD & Blu-ray RecordersReplies: 2Last Post: 28th Jun 2007, 19:56
