anyone know how to relax asp contraints?
i tried to build a vcd from xml. In the process of compiling the xml, errors msg like below appeared:
anyone know how to solve this? the pop up dialog box suggest to change chapters and to relax asp point. i want to solve the problem of having same entry point but dunno how.Code:....... scanning mpeg sequence item #2 for scanpoints... already scanned... not rescanning pbc: psd size 888 (extended psd 1120) iso9660: highest alloced sector is 64812 (using 64813 as isosize) requested entry point (id=entry-002) at 80.080000, closest possible entry point at 80.200000 requested entry point (id=entry-004) at 283.680000, closest possible entry point at 283.680000 requested entry point (id=entry-005) at 354.080000, closest possible entry point at 354.080000 requested entry point (id=entry-006) at 420.320000, closest possible entry point at 420.320000 requested entry point (id=entry-007) at 460.120000, closest possible entry point at 420.320000 Attention: several chapters at the same entry point (if it is not what you wanted... change your chapters) entry point 'entry-007' falls into same sector as previous one! requested entry point (id=entry-008) at 562.080000, closest possible entry point at 552.080000 requested entry point (id=entry-009) at 628.320000, closest possible entry point at 618.320000 requested entry point (id=entry-010) at 675.840000, closest possible entry point at 618.320000 Attention: several chapters at the same entry point (if it is not what you wanted... change your chapters) entry point 'entry-010' falls into same sector as previous one! requested entry point (id=entry-011) at 760.080000, closest possible entry point at 750.080000 requested entry point (id=entry-012) at 827.600000, closest possible entry point at 816.160000 .......
but how?
pls help. thanx.
I use 1.1.5.2. There is a checkbox on the tab where you add your mpeg that relaxes aps constraints.
Software used (until you guys/gals enlighten me):
DVD Decrypter
DVD Shrink
CopyToDVD
Nero 6
VCDEasy
TMPGEnc
In the more recent versions of VCDEasy, this "relax" option appears in the "main" page when the Expert mode ("File" menu) is ON
delphi.stuff
from premiere pro timeline to mpeg4 asp
By codemaster in forum EditingReplies: 5Last Post: 1st Jan 2012, 05:21 -
Using FFmpeg with C#,ASP.Net
By DanielTaylor in forum ProgrammingReplies: 0Last Post: 23rd Jun 2010, 04:19 -
Extracting xvid (V_MPEG4/ISO/ASP) from MKV
By 20000RPM in forum Video ConversionReplies: 2Last Post: 7th Feb 2010, 20:49 -
SSI to execute ASP or PHP?
By lordsmurf in forum ComputerReplies: 0Last Post: 19th Jun 2008, 05:14 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 06:00
Statistics
Newest guides
Latest tool updates
New media comments
