Yes, you pop up at every opportunity to rant about this.
Though as for "detailed": "a codec pack", and "fucked"?
Yeah, right, that's very specific and detailed.
Could hardly be more plain vanilla.Contents of K-Lite Codec Pack (Basic) version 7.6.0:
ffdshow: ffdshow [revision 3964]
DirectShow audio decoding filters: LAV Audio [version 0.31 build 2011-08-08]
DirectShow source filters: Haali Media Splitter [version 1.11.96.14],
LAV Splitter [version 0.31 build 2011-08-08]
DirectShow subtitle filter: DirectVobSub (a.k.a. VSFilter) [version 2.40.3611.0]
Other filters: Haali Video Renderer [version 1.11.96.14]
Tools:
Codec Tweak Tool [version 5.0.7]
Win7DSFilterTweaker [version 4.5]
Don't know how you could have fucked that up, not really interested.
Results 61 to 85 of 85
Thread: What is the best Codec Pack?
Try Codec Tweak Tool
If anyone interested, you can try SAF (Stand Alone Filters).
It was primary developed for HTPCs (MediaPortal, GB-PVR/NPVR), but it can work as a standalone player too.
More info: http://forum.team-mediaportal.com/codecs-331/saf-v6-00-based-lavf-95635/
Download: http://hobring.esero.net/saf/binary/
You should be able to play nearly all formats including MOV and RM, with minimal system changes (no need to have install anything else). -
Alan when was the last time you truly tested a codec pack? And I don't mean install and see if it works. One of the last steps i use when installing a codec pack is to uninstall it and compare it to a snapshot of the system prior to installing the codec pack. It's been a bot over a year since i have done so but CCCP nor K-lite clean up after themselves very well. If the developers of the codec packs can't get that part right what else are they missing?
Murphy's law taught me everything I know. -
@dragonkeeper: Yep.
I had to remove CCCP from somebody's system recently because it massively screwed up AVI capturing abilities.
Uninstall was far from thorough.
I was literally minutes away from a full format, before I found the last bits of crap.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video -
I'm not playing with my system to prove a point to you.
Which you probably would just dismiss against your own experience anyway.
Go to the respective forums associated with the codecs and ask the users and maintainers such questions.
Or you can follow the Reverend Smurf and just say that they're all the work of Satan and should be killed with fire.
My general view is that codec packs are in concept simply packages of individual codec installers. The pack installers try to reduce the conflicts and rationalise the way the codecs work together, that is their major value, beyond simple convenience. I think the major ones: K-Lite, CCCP, Shark007, all do this well now.
Many individual codecs have inadequate installers and uninstallers.
Feel free to install each codec with its own installer. Certainly it will take much longer, and I doubt you'll get a better result, but if you mistrust the pack installers, go ahead.
The basic problem is that Microsoft has failed to provide a simple safe mechanism for third parties to install codecs. They're only concerned with their own media player and formats, and anyone who wants anything else is on their own. -
as a non codec pack user i can only comment on what i've seen from users here and tried to help them with. 99 out of 100 posts here about any codec pack are people desperate to get some form of video back working properly on their computer after installing a pack. not glowing comments about how good they are. mostly from what i've seen a re-format/re-install of windows is about the only way to "fix" codec pack problems. then the posters go away and aren't heard from again. hopefully having learned a lesson albeit the hard way.
i'm another one who has never and won't be testing any codec pack ever- so it's all heresay to me anyway.\--
Actually, 99 out of 100 posts about codecs are the same two or three people repeating that story.
I challenge you to provide two links to posts here in the last five years that actually were "people desperate to get some form of video back working properly on their computer after installing a pack." Let alone 99.
If you can, I'll apologise.
If you can't, please don't repeat this crap.
Anyway, K-Lite works for me, and its installer fixed the mess a media converter installed by my daughter created.
But if you install every codec pack with every possible codec activated, then yes, you could be in trouble. So as the doctor said, don't do that. Install one pack and activate only the minimum/basic set of codecs to begin with. ffdshow is included in all packs and goes a long way. Pay attention to the questions the installer asks rather than ticking every box. Look at the diagnostic and repair utilities included.Last edited by AlanHK; 10th Nov 2011 at 08:36.
Playing with? it's a simple thing to un-ionstall and reinstall a codec pack, at least that's what you would like us to believe. And like i said I do it just to try the codec packs out if they could get the codec packs right then i could recommend it to my friends and family instead of the usual of trying walk them through installs over the phone. Believe me I'm in favor of codec packs, but being able to play video is not my definition of "it works". Did it break something? Is my primary concern which my primary concern, which often happens. Now if I could just uninstall and try a different codec packs until i get to one that works well on the system I'm tinkering with great. But that usually cause more problems.
So i have to try to figure out what caused the failure and why. Doesn't always happen but it happens enough for me to stay away from codec packs. It's much easier to manually install what is needed and leave it be. In truth if all you do is watch video you will probably be ok with a codec pack. but as you start installing capture software, programs to convert video there is probably a very good possibility you will experience problems related to codec packs.
I'm speaking from experince of wroking with many peole and build probably thousands of PCs over the years ()only to have many come back because they can't play a wav or avi or my personal favorite Winamp was working but now X, (this problem seems to always be related to a codec pack).
Misguided dribble once you have to work on someones PC that is totally fubar and you can't do a format for what ever reason they have given. Come talk to me again on this point. (it takes entirely to long to fully clean up behind a codec pack.)
Point out one problem due to some one installing a codec, the only time i've seen it be an issue is if the user had previously installed a codec pack.I install 5 pieces of software and if yet to find video i can't play. Seems the only way to do that with a codec pack is to install everything and then you're up the creak.
As much as i would like to, this is just one of those times I can't blame Microsoft. I write tons of code for all types of things installing has never been a problem. If the developers can't grasp this simple concept they should stop doing what they are doing. Cleaning up behind yourself is just good house keeping and is easily done. If you are putting wrappers around software developed by others the first thing you should do is fully understand what their software is doing, until you do this how can you successfully install\uninstall it? You can't, you can however get it working to some degree, which will suite most people as they are easily satisfied you just happen to be one of those people. Nothing wrong with that but for those who expect things to work as intended DON"T EXPECT SUCH FROM CODEC PACKS." which is the point a lot of us are trying to make. You fan boys are dirtying up the water with your blind faith.Last edited by dragonkeeper; 10th Nov 2011 at 10:34.
I'm not trying to "make you believe" anything, obviously nothing I say would change your mind.
I don't have blind faith in anything, let alone codec packs.
I note that in all the horror stories people recount, there is never any detail of which codec pack, which version, what options. Just "He installed a codec pack and his PC went up in smoke!!!"
The problem usually is that the user has installed multiple media programs that may have changed codec settings, multiple codecs and codec packs, not read any instructions, and finally they end up with a dozen copies of ffdshow installed on their desktop, and other weird places and fuck knows what else.
When I've setup a new PC and a K-Lite basic version, never had any problems.
Not a testimonial, not a guarantee, just reporting a small item of data.
Please feel free to roll your own solution, I don't get a percentage either way. -
i think from now on i'll just quote someone else when codec packs come up.
DO NOT install any of CODEC packs. If you already have, remove them. If you don't you can pretty much count on problems
jdobbs--
I suggest intalling the LAV Filters. It's just three codecs, but they play just about everything under the sun. Unless you need to use the XviD encoder (or for that matter, any other third-party encoders), you shouldn't need these rediculous codec packs, as they really do clutter your computer with all matter of unnecessary garbage. I also recommend installing VSFilter if you need/want to use subtitles.
Based on what I have read here, I'm guessing that codec packs are very hit-and-miss. I can't say for sure whether any are good (although I did have quite good luck some years ago with CCCP), but I will say that bad news tends to travel faster than good news. Anyway, if you want to avoid the frustration, I strongly recommend LAV Filters (and maybe VSFilter), and nothing else unless necessary.
Also, perhaps one might benefit from reading the changelog from whatever codec pack the use (or plan to use) to see if many of these "bugs" (assuming that they do exist) are fixed. -
with these codecs i have no problems with any format(yet?)
real alternative
quicktime alternative
K-Lite Pro Codec Pack
use Gspot to ID
PS3 Media Server
i always used CCCP codec pack but had problems with a couple of MKV Files
now never looked back
all the above do everything most of us want
the only thing i dont use is media player classic, i prefer media centre & media player 11 -
1. The software you use to play RM and mov files, both come packaged with MPC. maybe the authors are trying to tell us something.
2. Use of codec pack, but you did redeem yourself by adding yet to your statement. The initial description of k-lite reads to say "By installing this software you will be able to play any audio video format". So of course the less informed are gonna select all, so they can play any and everything. The description does go on to say "if you install all the included codecs/decoders you might get problem with other video software on your computer."
One statement pretty much contradicts the other.
3. You use WMP 11. (Granted WMP 11 is 2 twice as good as previous versions, but it's still not half as good as MPC or VLC). Well there is one thing that WMP does better, DRM.
That description is written by someone at Videohelp trying to cover all the bases, not K-Lite.
See
http://www.codecguide.com/about_kl.htm
http://www.codecguide.com/faq.htm
for what K-Lite maintainers say.
But yes, if you want to ignore the defaults and install everything, you can. It's not a magic bullet, no one claims it is, and doesn't stop you shooting yourself in the foot.
In my experience it can reliably deactivate codecs or uninstall. So it's usually not fatal. Those who install K-Lite Mega, then CCCP, then add a few others piecemeal, are going to have a harder time undoing it.Last edited by AlanHK; 13th Nov 2011 at 00:54.
Really ?!?!?
An 8 year old thread still going ?!?!?!
I have not wasted enough time to go through the post's to see who and when it it was dug up.....
But one thing is 100% for sure!!!!
99% of the time, Giving someone a codec pack is like giving a chimp a loaded gun!!!
PERIOD!!!
That has to be one of the biggest load's of BS i have ever read!!!!
Spoken (written) like a true clueless idiot!!!!
Just 3 codecs will play the hundreds of different video formats out there ?
You really don't get it do you ??Originally a member since 2001, LONG LIVE TARAN's!!!
Alan the description provided by the maintainers is just as miss-guided for the ill informed.
The K-Lite Codec Pack is designed as a user-friendly solution for playing all your audio and movie files. With the K-Lite Codec Pack you should be able to play all the popular audio and video formats and even several less common formats.
As a newbie the description alone tells me this is a "magic bullet". So of course I'm gonna install everything, and why shouldn't I the bullet points re-assure me it's the right thing to do. Among the bullet points are;
*The pack is suitable for both novice and expert users.
*The installer is able to detect broken codecs and filters on your system, and helps you to remove them.
* The installer is able to detect and remove over 100 different codec and filter packs.
* Uninstallation removes everything that was installed by the pack. Including all registry keys. All changes are properly undone.
The third bullet point is where I really have a problem granted it has been a over year since I tested any codec packs and I wouldn't knock them so hard if i had found this to be true. Also for a successful uninstall my expectation is as follows; return my system returned to the state it was in before I installed the software, points 2 and 3 make this a near impossibility. But a lot of apps fail at this, not just k-lite.
I agree with most of what you said here, but if i read the description as listed on the maintainers page "magic bullet" is exactly what I come away with which gives much credence to Noahtuck's comment at least in the case of newbies.
My point was that you were quoting a third party as if they were the creators.
Like almost everyone in this thread who vehemently quotes unnamed people without context to support their views of software they've never used themselves, yet somehow have a strong prejudice against.
If you just install the basic version with default settings, on a computer that isn't already seriously fucked up, you will be fine. Many people have virtually bricked their PC frantically trying one thing after another, compounding the problem.I agree with most of what you said here, but if i read the description as listed on the maintainers page "magic bullet" is exactly what I come away with which gives much credence to Noahtuck's comment at least in the case of newbies.
Nevertheless, its installer does a very good job of detecting and uninstalling/replacing existing codecs, even botched installs, in my experience.
I can't work up much sympathy for people who don't read instructions in front of them and later complain they weren't stopped from doing something dumb.
But if you think the description is misleading, maybe you should raise that on their feedback forum.
http://codecs.forumotion.net/f2-feedback
But consider: most of the individual codecs barely have a readme. You're demanding a much higher degree of handlholding from K-Lite, an entirely free service. Nobody would need or want a codec pack if it was actually simpler to install each codec individually.
What I said, basically. Except that applies to codecs in general, whether in a pack or not.
But instead of having to laboriously shoot yourself six times, a codec pack lets you use full auto and empty the clip all at once.
So you save a lot of time.
Klite Codec Pack
By pepegot1 in forum EditingReplies: 6Last Post: 2nd Feb 2012, 21:39 -
Klite Codec Pack
By pepegot1 in forum EditingReplies: 1Last Post: 27th Jan 2012, 13:44 -
what best video codec pack for edius6 ?
By atomicock in forum EditingReplies: 10Last Post: 7th Dec 2011, 11:14 -
K lite codec pack
By Pumkinhead in forum User guidesReplies: 14Last Post: 26th Oct 2010, 13:12 -
Codec Pack selection?
By therock003 in forum Newbie / General discussionsReplies: 4Last Post: 21st Oct 2007, 10:50
