I promise I have searched and read posts, but I still can't find one simple guide. I simply want to transfer Hi8 tapes to DVD-R. I have my Hi8 camcorder connected to the analog pass through of my TRV22. I have captured the full tape into an .avi with WinDV. Now for the question(s):
What is the easiest way to get the .avi to DVD-R so that I get good as good of picture from the DVD-R as the original Hi8. If necessary, please provide instructions for 1 hour per DVD and 1 hours per DVD.
Thanks in advance.
Look in the Guides at the left of your screen and there arte many there. They show the software needed for each guide. Pick the ones using the software you have or read them all find the best for you and then get the Software needed. Sorry not to be more specific but Conversion seems to be a personal thing 20 people will give you 20 BEST ways of doing it.
Hi,
These two links might be of interest:
http://www.dvdrhelp.com/forum/viewto...482&highlight=
More towards the end of the link above - A detailed approach to using good / the best tools at each stage. Or...
http://www.dvdrhelp.com/forum/viewto...131&highlight=
The following is a quote from the second link (an all in one tool, don't know what the ouput quality is like):
Might be of use.Here it is plain n simple, after hours of painstaking trial n error this is what i came up with.
If you have a divx, avi or mpeg you want to convert to dvd, use neodvd+, this will convert your file into the necessary vob + inf files you need, neodvd+ will create the AUDIO_TS + VIDEO_TS files. When you have these files you can simply burn these to a dvdR as data files, dvd rom.
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Easy way to default existing subtitle to "on" when backing up?
By Spoffo in forum SubtitleReplies: 1Last Post: 30th Jan 2011, 21:50 -
Arrgh.. "Easy Video Splitter" doesn't seem to work with Windows 7
By Wakewatcher in forum EditingReplies: 10Last Post: 14th Jan 2011, 22:19 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
A good, "easy" program that can edit a DVR disc?
By Arglameth in forum EditingReplies: 1Last Post: 23rd Feb 2009, 09:58 -
Tools suggestion: adding "see also:" to the searched tool ?
By vhelp in forum FeedbackReplies: 0Last Post: 22nd Feb 2009, 11:03
Statistics
Newest guides
Latest tool updates
New media comments
