VideoHelp.com Forum
Thread: DVD Regions
  1. Hi
    Is it possible to change the region code for a DVD from 1 to 2.
    I generally use DVDXCopy or DVDXPress or DVD Dyvrypter
    thanks
    Neil
    Why do you need to set the region of your DVD from 1 to 2 ?... Isnt it best to set it to region 0 (region-free) ...?
    Originally Posted by NeilJ
    Hi
    thanks
    Neil
  3. Ok but what i'm after is to be able to back up the DVD's that I have and play them on my region 2 player in which case it still poses the same question
    How do you change a DVD from region 1 to region2 "or 0"
  4. Member MackemX's Avatar
    Ifoedit can set it to '0' by clicking just a button or you can do it manually using Ifoedit also to set it to any region you want
    check out SmileyPic if you love using smileys :) (LINKSKI)
  1. Need to decode Sony DVD to play all regions
    By Rhonda in forum DVD & Blu-ray Players
    Last Post: 22nd Apr 2011, 22:36
  2. Various Regions PAL DVD's
    By dblan9 in forum Authoring (DVD)
    Last Post: 11th Mar 2010, 17:10
  3. Code to allow DVD use on all regions
    By eaglet in forum Newbie / General discussions
    Last Post: 29th Mar 2009, 11:04
  4. Data DVD Regions?
    By cyberdrugi in forum Newbie / General discussions
    Last Post: 3rd Dec 2007, 14:06
  5. How to change regions on a DVD or TV?
    By SnowStormWolf in forum Programming
    Last Post: 8th Jul 2007, 17:11
