VideoHelp.com Forum
  1. Hello, I am planning to buy a Sony 60" HDTV Projection TV with DVI Input, I have the ATI-ALL-IN-WONDER 64mb DDR Video Capture Card and it has DVI output, I am debating if I should buy a Sony Trinitron 21" Pure Flat Screen Computer Monitor, or just wait till i buy an HDTV with a DVI connector and use that as my computer monitor, What would be the quality? would it be better than a computer Monitor? would it ruin my TV?
    would the computer monitor give out better quality?
    What do u all recommend i should do?
    Thank You
  2. Can anyone Help?
  3. Член BJ_M's Avatar
    using a 60" hdtv as a pc monitor will look like crap for text and such as that --- should be allright for games
  4. If it is anything like s-video out then it will suck for reading text. But gaming and watching videos is fine.
  5. Член BJ_M's Avatar
    DVI is much higher quality than s-video .. that is not the problem, its the large dotpitch in the hdtv tv plus convergence errors ...
  6. I just got a HDTV projection TV, the manual is still on my desk... It states that the DVI connector is not for a personal computer. It's DVI/HDCP, meant for protected digital programming (digital set-top box).
    I thought the same thing when I saw the connector on the back
  1. Replies: 8
    Last Post: 14th Sep 2010, 03:40
  2. Replies: 3
    Last Post: 31st Jan 2010, 23:23
  3. LCD HDTV does not have analog coaxial connector
    By phamily06 in forum DVB / HDTV
    Last Post: 16th Oct 2009, 07:53
  4. Replies: 2
    Last Post: 6th Aug 2008, 21:43
  5. Computer DVI output to TV DVI input
    By superdud1400 in forum DVB / HDTV
    Last Post: 13th Jul 2008, 09:44
