VideoHelp.com Forum
  1. Does anyone know of a way to capture streaming video such as Flash, from a web site and then convert to an avi?
  2. Member djmattyb's Avatar
    First save the flash .swf file to your hard drive. Then try this program. It's called SWISH. You can get it from http://www.swishzone.com/. The demo scrambles the movie output, so you have to get the full version. I love SWISH. It's really easy to use if you are trying to create some advanced text animations using Flash.
    Good Luck!
    -Matt
    dj matty b
  3. If you want to convert flash to avi, I recommend you using Magic Swf2Avi(http://www.effectmatrix.com), which is the only tool that can convert with lossless audio.
  1. Replies: 1
    Last Post: 23rd Mar 2012, 11:08
  2. How to capture/record streaming Google, youtube,Flash, ASF,WMV,RM,Quicktime
    By Baldrick in forum Newbie / General discussions
    Last Post: 21st Feb 2012, 22:41
  3. capture device for live streaming via a flash player
    By haastyle in forum Video Streaming
    Last Post: 21st Jan 2010, 10:03
  4. Streaming Live Video to a Web Site in Flash?
    By jax1492 in forum Newbie / General discussions
    Last Post: 26th Jul 2007, 12:15
  5. Is it possible to save streaming flash video from web site?
    By tigerb in forum Newbie / General discussions
    Last Post: 5th May 2007, 17:08
