Hi - ffmpegx seems to be choking as soon as it tries to encode the audio on one file. The video goes through, no problem, but then it fails as soon as it tries to do anything with the audio.
The output is below - is this a problem with my configuration or the file I'm working with?
Encoding started on Sat Nov 29 06:36:13 MST 2003
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=352x240, frame rate=24000:1001 fps)!!
error: could not convert audio track!
**ERROR: EOF in WAV header
**ERROR: failure reading WAV file
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Volumes/Media/Downloads/ movies/AboutSchmidt_1_part1/movie.m1v looks like an MPEG Video stream.
**ERROR: [mplex] Unable to open file /Volumes/Media/Downloads/ movies/AboutSchmidt_1_part1/movie.mp2 for reading.
Thread: ffmpegx fails to encode sound
Which format is your input file?
Hi - the file info is:
VIDEO: DivX, size: 512x272, 23.976 fps, 1106 kbps. AUDIO: ac3, 48000Hz, 448 kbps.
Since your audio stream is AC3 and you use "Decode with Quicktime", you should make Quicktime able to play AC3. For that, try to install this Quicktime AC3 codec
ffmpegX not encoding properly -- fails after 7%
By larrryc in forum ffmpegX general discussionReplies: 2Last Post: 22nd Apr 2010, 14:07 -
i cannot encode with ffmpegx
By Se0r in forum ffmpegX general discussionReplies: 8Last Post: 24th Sep 2009, 12:38 -
FFMPEGX won't encode!
By Kalasin in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2009, 11:02 -
What encode does FFMPEGX use for FLV?
By pieman1968 in forum ffmpegX general discussionReplies: 1Last Post: 3rd Apr 2009, 13:16 -
FFmpegX can't encode vobs
By sgee34 in forum ffmpegX general discussionReplies: 3Last Post: 15th Jun 2008, 17:07
