I have finally solved the problem with VCDEasy's media player when using MPEG2 files. The sound would work OK but no picture. If you used any buttons on the player VCDEasy would dissappear.
It also fixed my problem of not being able to cut/merge mpeg2 in TMPGE.
It has also fixed my problem with Windows Media Player. MPEG2 files would play OK but using any buttons would bring up an error.
I had these problems even with PowerDVD installed.
THE SOLUTION -
I reinstalled Interactual player that comes on many DVDs.
I had this on in the past but uninstalled it.
YIPEEE!!!!!!!!! (some of us are easily pleased)
Results 1 to 1 of 1
Thread: IT'S FIXED !!!!!!!!!!!!!!
extract vob with subtitle fixed!
By c0ntr0lz in forum SubtitleReplies: 1Last Post: 6th Jun 2010, 00:40 -
Can this blend be fixed?
By alcOre in forum Newbie / General discussionsReplies: 8Last Post: 20th Jun 2009, 13:02 -
Can video corruption flaws be fixed?
By kayumidome in forum RestorationReplies: 9Last Post: 5th Apr 2009, 11:54 -
Can vertical oscillation be fixed?
By davexnet in forum Video ConversionReplies: 11Last Post: 19th Feb 2009, 20:11 -
by looking at this picture can it be fixed?
By effects in forum RestorationReplies: 4Last Post: 27th Aug 2007, 15:01
