VideoHelp.com Forum
  1. I have a HP200i (listed as 200J) dvd burner, using anyDVD and CloneDVD. My problem is that I recently burnt about 6 discs in a row. The first one was fine, it played on computer and DVD player. The second only plays on my computer and not on my DVD player. Third disc was fine, fourth disc only plays on comp., and the fifth was fine, etc. When I look at the bottom of the discs, on the inside rings, where the burning starts, there is a little blank space. On the good DVD's its only 2mm or so (guessing at size) and on the ones that only play on the comp. its like 3 or 4mm. I don't think its the media, on the fifth disc...after seeing a little pattern I grabbed the disc below the one I would have used and it still came out bad. Anyone know what it could be causing this, any ideas on how I can fix it . I would like to stick with these programs if I can. Thanks to anyone who can help me with this
    aaron smith
    u4ricone@aol.com
  2. - bad media --- get better ones
    - outdated firmware --- update it
    - bad burning engine --- update to the latest CloneDVD or use RecordNow to burn the file created by CloneDVD
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  1. Half of DVD Doesn't Play
    By theWallflower in forum Authoring (DVD)
    Last Post: 20th Dec 2011, 22:08
  2. VCD cannot play in PC but can play in DVD player
    By avatar123 in forum Authoring (VCD/SVCD)
    Last Post: 3rd Jan 2011, 16:32
  3. Replies: 13
    Last Post: 16th Sep 2010, 05:39
  4. DVD will play on new DVD player, but won't play on old
    By joe8915 in forum Video Conversion
    Last Post: 18th Feb 2008, 18:57
  5. Replies: 1
    Last Post: 22nd Oct 2007, 11:30
