here is a pic which shows my dvd burner info using dvdinfo. it a nec 1100a burner, according to this prog the region code for my burner is 2. since i bought it used i dont know if it has has the region changed before but it says i can change it 3 times more if i want to. my questions are this, can i change it to region 0? if so how do i change it? is there a software that changes the region on dvd burners?
any help appreciated.
Thread: nec 1100a region code change
There is no pic hear to make it region free just use DVDregionfree or ANYDVD at www.slysoft.com
sorry here is the image
so if i install dvdregionfree will the dvd i burn myself be region 0 if i want it to be?
Yep, very few applications allow you to set anything other than all region when it comes to burning.
take a look at
http://etna.rpc1.org/nec/index.html
there's firmware to make the drive region free and even a bitsetting hack. of course, it can be a very risky thing and if a flash goes wrong, then you can kill your drive. so do it at your own risk.
there was a bug in the autoreset firmware for the 1300A, but I don't know if that is also in the 1100A modified firmware.
to change region code panasonic DMP-BDT110
By elprofesor in forum DVD & Blu-ray PlayersReplies: 7Last Post: 5th Aug 2011, 12:35 -
cannot change region code from 1 to 2
By decocal in forum Software PlayingReplies: 6Last Post: 16th Oct 2009, 04:27 -
citizen c201 dvd region code change
By citizen007 in forum Newbie / General discussionsReplies: 4Last Post: 21st May 2009, 10:25 -
Can't change region code
By The-One in forum Blu-ray RippingReplies: 0Last Post: 22nd Mar 2009, 11:19 -
Need to change Region Code for NEC NDRV-60
By alexspag in forum DVD & Blu-ray RecordersReplies: 4Last Post: 11th Dec 2008, 08:19
