In dvd-lab beta 8 I tried to use in a 50 min film that I captured from Ld the Rewrite GOP . It goes well until 40 min, after that the timecode stays wrong. Then when I mux and compile, the dvd in the exact moment that went wrong freezes on the player.
Help !
Thread: Dvd-Lab Rewrite GOP Timecode
Beta reports should go to the official forum for evaluation and bugfixing.
No one around here can fix that.
If you must use the Beta for serious work then use Tmpeg DVD Author Cut/Join to re-write the mpg - that fixes any timecode issues.
Convert NTSC DVD and rewrite to PAL
By murihikukid in forum Authoring (DVD)Replies: 3Last Post: 12th Sep 2011, 07:48 -
Not able to rewrite DVD+RW media in DVD recorder
By ipolicky in forum Authoring (DVD)Replies: 3Last Post: 24th Oct 2009, 12:48 -
DVD Lab Pro timecode problem on Vista
By jonghyunchung in forum Authoring (DVD)Replies: 1Last Post: 4th Jan 2008, 19:58 -
[ERR] GOP size is over the buffer limit - Compiling in DVD-lab PRO 2.30
By Wolverene in forum Authoring (DVD)Replies: 7Last Post: 31st Aug 2007, 22:55 -
ES Video and GOP timecode
By arturo83 in forum DVB / HDTVReplies: 8Last Post: 21st Aug 2007, 06:57
Statistics
Newest guides
Latest tool updates
New media comments
