Can anyone tell me why the audio goes out of sync after I convert it from avi to Mpeg.
I fix all the bad frames and avi plays ok-no audio sync promblems. BUT when I convert it to mpeg with Tmpg sound comes before video. To fix bad frames I use guide 153907"Fixing bad frames without losing any audio"
Welcome to the real world. If it's off by the same amount thru the whole movie, it's easily fixed by adding some audio skew in TMPGEnc, or extracting the audio to wav and adding some silence at the start.
Many believe that an AVI that plays fine using some media player must be OK, but that's not the case. Media Players are very tolerant - encoders are not.
/Mats
well,you have to use audio decopressor(from avi2vcd software) instead of avi2wav,goldwave or any other software some people recomand here,You'll get a "pcm"file of about 2Gbyte for a 90 min movie.Use this file for both video and audio inputs to Tmpgenc and everything will be OK
Audio out of sync after conversion
By user2008 in forum DVD RippingReplies: 5Last Post: 13th Nov 2010, 05:13 -
After conversion audio is out of sync
By videojunkie7 in forum Video ConversionReplies: 0Last Post: 23rd Nov 2009, 18:06 -
Audio Conversion out of sync
By Silsur in forum AudioReplies: 8Last Post: 13th Oct 2009, 17:45 -
force audio sync during conversion
By dtmp in forum Video ConversionReplies: 1Last Post: 5th Aug 2009, 16:52 -
AVI Conversion - Audio out of sync
By pinovecs in forum Video ConversionReplies: 3Last Post: 17th Oct 2008, 16:11
Statistics
Newest guides
Latest tool updates
New media comments
