VideoHelp.com Forum
  1. guidorobben
    Guest
    I cannot find a cancel button. Can i just press the x on the form to stop the process?
    guido
  2. Member p0rnLiME's Avatar
    Why don't just push [x] and see?
    If not Ctrl+Alt+Delete should give you some help, or you could even try Alt+4.
    As far as I remember there are many tabs with options in this program, and I think there should be a cancel button under "Encoding", but I'm not really sure...
    10110101100111012011 <- The bug Bill doesn't talk about.
  3. Mod Neophyte Super Moderator redwudz's Avatar
    If this program works similar to DVD2SVCD,which generally refuses to stop, and if you are using XP OS, one way to stop it is to go to the Task Manager and stop it there. No need to reboot then.
  4. This program has got nothing to do with and isn't similar to DVD2SVCD.
    Greatings,
    Yf
  5. Member ChrissyBoy's Avatar
    Just close the form. That stops SVCD2DVD. The current process (mplex, dvdfolders etc) will either need to killed manually (taskmanager) or it will stop when its finished processing.
  1. Replies: 3
    Last Post: 31st Oct 2009, 06:45
  2. Process description.....
    By zok4me2000 in forum Authoring (DVD)
    Last Post: 4th Jun 2009, 11:25
  3. Where is the Stop or Cancel Button in VOB2MPG ver. 3?
    By SuperFist in forum SVCD2DVD & VOB2MPG
    Last Post: 3rd Jun 2009, 04:27
  4. New Computer > Need New Process
    By msdker in forum Newbie / General discussions
    Last Post: 14th Mar 2009, 17:18
  5. Replies: 6
    Last Post: 22nd Apr 2008, 10:27
