I did some encodes recently in "safe mode". This seemed to take quite a while longer than in normal mode - anyone know why ?
Results 1 to 9 of 9
Thread: Normal vs Safe Mode
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
for the $2,000+ you paid for the encoder I would ask cinemacraft. or "backgrade" to v2.50.
if your using windows 95,98 or me in safe mode windows uses 16-bit disk drivers and no DMA not sure about xp though
Your Nickname Was Never Ace, Maby Ace Hole
Browney_wigan
he may not be talking about his OS...BTW he's running Win2k (place your mouse pointer on his [or your's, mine, etc] computer details button)
I am talking about the OS . . but am using TMPGenc not CC.
yes sorry i forgot about the computer details
im not sure about safe mode in 2K/XP but it wont use 16-bit drivers because its a compleatly 32-bit os unlike 98/ME
but dma may still be disabledYour Nickname Was Never Ace, Maby Ace Hole
Windows safe mode only loads the bare minimums to get the OS up and running so you can fix any problems that occurred during a normal bootup.
I'd make sure that your machine boots up clean and run in normal mode when doing CPU intensive tasks like capturing and encoding.
why are you in safe mode if normal is working
pardon my ignorance regarding CCE.
Getting too many BSOD in normal mode when encoding. Its probably time for a clean install of 2k, but I am sooooo lazy when it comes to doing stuff on the PC that aint funOriginally Posted by noki
BSOD - Window doesn't load normal/safe mode
By hoon88 in forum ComputerReplies: 21Last Post: 25th Oct 2009, 07:49 -
Cannot change resolution when in safe mode
By mysts in forum ComputerReplies: 5Last Post: 23rd Oct 2008, 13:24 -
WindowsXP is @#%ed - how to burn CD from safe mode?
By sdsumike619 in forum ComputerReplies: 7Last Post: 19th Oct 2008, 23:16 -
safe mode screen?
By alintatoc in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2007, 17:27 -
help! i can only boot in safe mode
By ted demen in forum Newbie / General discussionsReplies: 30Last Post: 6th Jun 2007, 07:51
