Helo,
can't find similar problem by searching:
Conected my analog camcorder to digital one, and captured to avi file to the computer. So long everything is fine, avi has a good quality. But if i now try to code with DivX or Tempeg or CCE or whatever, the playback on the computer is slowmotion, then it hurries up a second than again slows down. The Audio stream is alright. I've tried all different settings, even different GOP's, but the problem stays the same.
Anyone got a clue? Would appreciate it.
1cu
Your computer may not be fast enough to decode mpeg2 in realtime.
I was thinking the same, but Divx as well ?
I'll try playing at a friends computer, if you are right i tell you.
Thanks.
1cu
kinda sums it upOperating System: winxp
CPU Speed: duron600"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I' ve tested it on more powerfull computer, but it's not depending on that.
Tried again DivX with set Keyframe to 1. It bacame better, i mean the movie is now continously, but like dropped frames or stuttering.
1cu
Using AutoGK to convert from VOB->AVI results in slow-motion video
By WebMaximus in forum Newbie / General discussionsReplies: 5Last Post: 10th Feb 2012, 13:49 -
Movie slows playback like slow motion
By skorpinok in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2010, 04:10 -
Slow AVI playback?
By JeffM in forum ProgrammingReplies: 10Last Post: 24th Apr 2009, 06:44 -
Slow motion
By Pliny in forum MacReplies: 7Last Post: 7th Aug 2007, 00:02 -
Slow Motion
By sbuckmybballs in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2007, 02:16
