VideoHelp.com Forum
    Hi i used tinra to convert a rm file.
    the audio doesn't match so I tried extracting it to a wav and then using TMPGEnc but that didn't work the audio still doesn't match what can I do?
    before anyone suggests it I can't use eo video because my trial is up and can't afford to buy it right now because of the holidays. any other suggestions?
  2. I'm a Poll Super Moderator johns0's Avatar
    If i get video with audio out of sync i demux the mpeg in tmpenc then remux with bbmeg and set the delay to video to what i need or if the audio
    slowly goes out of sync i use sound forge to stretch or shrink the time line to match the video
  3. Member Ziffelpig's Avatar
    I dont know if womble mpeg-vcr will load your file, but you can get a fully functional trial.Estimate how much your file is out of sync, Demux your file with whatever you like, a simple demux in TMPGenc, open mpeg vcr, go to tools open the MPEG System muxer and load your video and audio files. Determine your format, give your file a name and hit the AV-Sync button, move the slider +- to your estimated time out of sync.OK, Save it, you might have to try this a couple of times to get it just right but it works very quickly.
    Just shut up and listen dumbass
  4. Member Laddydaddy's Avatar
    Does your audio/video gradually driftout of sync, or are they out of sync by the same amount of time throughout the video?
    the whole time
  6. Member Laddydaddy's Avatar
    You can use virtual dub. Since you used tinra I'm assuming the video is an avi file. Load your file into virtuual dub then choose audio>full processing mode. Then choose audio>interleaving. Read the instructions in the pop up box that appears. At the bottom of the box you will see another box called audio skew correction. If the audio plays too early you will use a positive number in the box. If it plays too late you will use a negative number. I usually start with 500 (or -500). Click ok and then play the video in virtual dub. If it is still not in sync go back ond change the number. It's really trial and error until you get the right number. When the a/v are in sync, choose video>direct stream copy and then file>save as avi. Your new fle should now be in sync. Remember to leave the audio in full processing mode when saving the file.
  1. Help with damaged avi - audio/video resync
    By hibbs in forum Editing
    Last Post: 16th Jun 2011, 22:20
  2. Resync slow dts audio track in MKV
    By forsh86 in forum Video Conversion
    Last Post: 17th Aug 2010, 21:22
  3. Resync Audio in WMVs?
    By FuzzyReets in forum Audio
    Last Post: 19th Nov 2009, 17:33
  4. Resync Audio & Video Of A x264 Movie
    By IMAN_r in forum Editing
    Last Post: 10th Dec 2008, 18:06
  5. resync audio on DVD9 w'out losing layer breaks?
    By itherod in forum Authoring (DVD)
    Last Post: 22nd Dec 2007, 21:00
