VideoHelp.com Forum
  1. Im trying to play some svcds on my pc , but the audio doesnt play...
    I installed the K-lite codec pack...... which includes a mpeg-2 codec (mybe couple/.....) ... so errrr ummm i dont know what to do... might be a problem associated with the k-lite codec pack... it said it couldnt register some file after instlling... everything else appears to play ine tho...
    Any indeas????
    mpeg1 layer2 audio should work fine, it doesn't require any extra codec. Something else must be wrong. Tried PowerDVD or WinDVD?
  3. Member ZippyP.'s Avatar
    I think you may be confusing mpeg2 video with mpeg layer2 audio. You need an mpeg2 video codec in order to play SVCD's (or DVD's) on your PC. I don't think K-lite has one. PowerDVD or WinDVD has one and PowerDVD will install one when you install the trial version.
  4. i have the mpeg 2 codec installed (for SVCDs)
    and it plays just the video on BSplayer..not audio..i also tried a couple other SVCDs and the audio didnt play in them eitehr..
  5. Where did you get the SVCDs? Are you sure that they contain audio (mistakes happen). As stated you need a MPEG2 codec to play the video, but the audio is MPEG1 layer 2 and requires no codec (WMP should be able to play it).
    Run the MPEG2 file through Gspot and see what it says about your audio. Also try ripping/coping the MPEG file to the HD, demuxing it, and seeing what the mp2 file looks like.
  6. Member ZippyP.'s Avatar
    I think Avicodec might be better for analyzing an mpeg.
  7. 100% positive it has udio, tried it on nother comp.,.. worked fine..
    the .mpg ile is in 'svcd' format (mpeg-2video , mpeg lyer 2 audio..i think)
    i think it is something to do with the mpeg lyer 2 audio codec not being registered.....or somthing... yea....??? not really sure... and i dont wnt to instll the new WMP 9 cuse i cant uninstall it...
    *ps there might be alot of the letter 'a' s missing b/c my keybord is a piece of.,..
  8. any suggestions???
    what should i reinstall? is there a way to reimstall WMP? (i dont really want the new ver.9)
  1. Dual Layer problem. Layer break issue...
    By papegoja in forum DVD Ripping
    Last Post: 9th Jun 2010, 22:52
  2. HELP - .mvk to .mp4 audio-layer problem
    By Sanzee in forum Video Conversion
    Last Post: 31st Oct 2009, 14:42
  3. AVI files - MPEG Layer-3 - audio conversion?
    By ChoonyFish in forum Video Conversion
    Last Post: 7th Feb 2008, 08:27
  4. Replies: 2
    Last Post: 26th Oct 2007, 21:51
  5. MPEG-1 audio Layer 2
    By dedine in forum Video Conversion
    Last Post: 4th Sep 2007, 15:51
