I have created a VCD (usng Nero) with al my holiday photos on, works fine, nice.
What I would like to do is add a menu so I can choose the holiday photos I want.
Is it possible to do this or do tjhe menus just point to all the files and you can't select the files you want to point to?
Example menu:
Holiday 1 (link on menu) points to photo 1
Holiday 2 (link on menu) points to photo 67
Holiday 3 (link on menu) points to photo 120
Possible?
Thread: VCD menus and Photos
Cheers, I will give that a look.
Another option owuld be to create 3 separate MPEG files. The first would have photo 1 - 66, the second would have 67 - 119 and the third would have 120 through the end.
Each one of these separate files would be the beginning of the chapter points on your menu.
I used to (in the old days of vcd) use a program called tscv (got it from doom9.net i think, anyway if you read about this prog (it was a freeware prog the last time i looked) it might just do what you're asking
I could dance with you till the cows came home..... on second thoughts i'd rather dance with the cows till you came home.
Rufus T. Firefly (Groucho Marx)
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 135Last Post: 14th Jul 2011, 13:48 -
Photos off DVD video made of photos?
By 5chandlers in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2009, 12:31 -
Going from high resolution photos to low resolution photos
By bryankendall in forum Newbie / General discussionsReplies: 6Last Post: 27th Jan 2008, 05:03 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 13:16 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 06:54
