VideoHelp.com Forum
  1. Help is needed to getting DVD files which are saved on my hard drive to be put onto a normal CD-R or several CD-R's, so that they can be treated like a normal film when playing on the PC like scene selection etc.
    I wanna treat it like a VCD or something similar so it can be played in my DVD player aswell (VCD S-VCD compatiable), using these files; VOB file, IFO file, BUP file. Can you tell me which each file one responseabilty is, what its main criteria, and how i can make it viewable like DVD style, on CDR's.
    Much Apreiceated, for the help.
  2. Member ZippyP.'s Avatar
    I'm not a DVD expert so I can't define all those files for you. The VOB is a Video OBject file which contains the audio and the mpeg2 video information.
    It's possible to get the whole movie on one CD in VCD format, or onto several disks in SVCD format. If you really want it to be like the original DVD then it's best to get yourself a DVD burner, CD's just don't hold enough to create the entire DVD experience.
    I think you should try your hand at making a few VCD/SVCD's before getting more advanced and creating disks with menu's and chapters. Here's a comprehensive guide that can take you from DVD to VCD/SVCD. I recommend using these tools in order: Smartripper>DVD2AVI>TMPGEnc>VCDEasy.
    Good luck!
    Edit: I found this in the "What is DVD-R" section, you might want to do some reading as this site has a lot of information.
    "Explanation:
    . BUP = Backup files of the IFO files.
    . IFO = The IFO files includes information such as chapters, subtitle tracks and audio tracks.
    .VOB = The VOB files contains the actual video,audio,subtitles and menus."
  3. you just need, as zippy said, is dvd2avi tmpgenc and then burn with nero or vcdeasy.
    DVD2avi ...easy
    tmpgenc ---more difficult .. start off by making vcd's.
    burn to disc ---easy
    The electronic components of the power part adopted a lot of Rubycons.
  4. Thanks Zippy for elaberating on the file types.. how long do you reckon the whole process, of
    DVD2avi ...easy
    if i had ermmmmm...... 3.5gb worth of VOB. I know its like hog long is a peice of string, but concidering it takes 2 seperate process of file formatting, and then burning to disc.
    thanks in advance.
  5. Member ZippyP.'s Avatar
    Originally Posted by MR MICHAEL
    how long do you reckon the whole process...
    DVD2AVI is fast, 15 mins. or so on my 1.6 GHz. system.
    TMPGEnc can take anywhere from a couple of hours to a couple of days, it depends on your system (esp. the CPU) and your settings. It usually takes me 5 hours or so using 2-pass VBR, motion estimate (fast) and no filtering. I encode over night. 8)
  6. http://www.dewayneward.0catch.com/videoindex.htm
    This link (to my website) will give you a good overview of the process and it has links to how to make vcd's,cvd's, and dvd's.
    It has a lot of popups (what do you except for a free web hosting site)
  1. problems making dvd from vob files only
    By Dr_Sanguinary in forum Newbie / General discussions
    Last Post: 17th Nov 2009, 07:20
  2. Making DVDs from backups of VOB files
    By kirklt in forum Authoring (DVD)
    Last Post: 26th Aug 2009, 08:52
  3. DVD Demuxer tool making 0kb .VOB files
    By Madvillain in forum DVD Ripping
    Last Post: 6th Jul 2009, 04:11
  4. Making a DVD menu from .VOB files created by FAVC?
    By whatever911 in forum Authoring (DVD)
    Last Post: 16th Feb 2009, 03:13
  5. making movie from many mepg/vob files
    By volam in forum Editing
    Last Post: 10th Apr 2008, 10:33
