Ad runs 11/9/03-11/15/03:
+R is made by Ricoh or MCC=![]()
-R is made by CMC or Prodisc=![]()
It must be a new item because it's not listed on their website.
Results 1 to 23 of 23
CompUSA has 25 pack's for $19.99 DVD-R
http://www.salescircular.com/
I got the +r at best buy
Media Information
Disc Regions are 1,2,3,4,5,6,7,8
Media code/Manufacturer ID RICOHJPNR01
Format Type UDF 1.02
Volume Name FINAL
Yeah but they're 1x CompUSA brand(FMI):Originally Posted by spiderman2k1
http://www.compusa.com/products/prod...id=dsr&ref=dsr
OFFICE DEPOT has 75 imation for 89.67. buy a 50 pack and get a 25 pack free. not sure about the speed though
or because best buy regularly removes sales items or they "quickly" sell out. you can have the same thing had at amazon.com for a penny cheaper, see my thread on that deal for the link. best buy will also charge you sales tax, if applicable, while amazon will not.Originally Posted by MOVIEGEEK
beyondgoodandevi how sturdy is the packing from amazon?
I just bought a 50-pack of DVD-R. They are CMC...but I haven't try any yet. Hopefully, they will work fine with my SONY 500A.
vcdlover
i just pick up the 50pk at bestbuy.
ok, i just have a simple questions..
It ALL Memorex 4x +R media made by Ricoh?
the UPC reads on the spindle 3470705544
more info on the side of the spindle
part # 32025544
made in Taiwan
Can anyone confirm which company made these dics using the part# and or upc code?
i just wanted to make sure before i open the package
I have had my share of sh!tty inferior media before.
thanks in advance!
-ty1er
we'll see how it goes - I picked up a spindle of the -R, and right now it's burning a backup of "Grey Gardens" at 4x in my Sony DRU-500AX.
in 7 minutes or so, I'll pop it in the disc player and check quality - it's a single-layer original, done as an ISO with DVD Decrypter.
update - disc worked great, burned at 4x consistently, and I checked the disc - no problems.
I'll have to download one of the id apps and see who the manufacturer is...- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Someone has now reported that he bought Memorex 4x DVD+R made by CMC Magnetics so I guess the answer is no.Originally Posted by ty1er
They burn at 2x on my Sony DRU500ax. Must have burned 200 of them so far with zero failures.Originally Posted by MOVIEGEEK
Until this week, I've had good luck with the dozen or so 25 disc spindles
of 4X Memorex dvd+R media that I've bought at CompUSA over the last four or five months. CDVDinfo identifies them as Ricoh, 2.4X/4X capable, etc. My plextor 504 likes them.
But the two Memorex "4X DVD+R"spindles I bought a couple days ago have no identifying info on disc, no certified write speed info, no manufacturer's ID, no media ID .... so all I get is a painfully slow 2.4X burn rate. They're in Memorex 4X+R packages, with the same disc surface decor, and CompUSA charged the Memorex 4X spindle price,
but they're real clunkers.
i tested these discs and they are manufactered by Ricoh.the UPC reads on the spindle 3470705544
part # 32025544
made in Taiwan
the weird thing was that i could not use DVDinfo on a blank disc (i kept on getting errors), i had to burn something to it first be being able to get the media code from it.
(i kinda thought that was wierd)
my burner is a plextor 504a
-ty1er
ok...here's the bestbuy ad....its now posted on there web site
http://www.bestbuy.com/site/olspage....5&type=product
if you don't want to order online and there is no bestbuy near you....bring it to staples....they have to match the price because it is not just an internet company...its a real chain of stores.
i think memorex + media has gone very cheaply very quickly, i had the same experience with some memorex + discs that i bought recently. these discs have the RICOH media code, too, although even newer memorex + discs are now apparently CMC discs!
the new bad RICOH discs (cannot speak to the packaging on the CMC discs) are only distinguishable from older spindles i bought in a very bizarrely minimal way: on the bottom of the spindle there is a 5 inside arrows forming a triangle with "PP" written beneath it; on top of the spindle there is the same thing. on the good RICOH discs, the ones i burned over 80 of with no burn failures, all at 4x, and all of which i've checked in dvd utilities have no burn errors, the 5PP on the top is big and the one on the bottom is smaller. on the new bad discs, ones that i burnt 5 coasters with before switching the speed to 2.4x and having no problems, the 5PP on the top is small and the one on the bottom is bigger.
i do not know if the same goes for the 50 pack spindles, if anyone else
has investigated this matter with the same microscopic examination that i have, please post your findings.
Originally Posted by jgnjgn
Bought the 50pk of DVD-R. Burned 4 so far at 4X on my Pioneer 105 with 1.21 firmware. Then I Bit compared the DVDs with the original files. No Errors. Looks like good media to me...
ty1er
you cannot read the code off a blank + media, only - media. with + media you have to burn something on it first.
BTW bought 2-25 paks of memorex 4x +dvdr from amazon weeks ago and they are ricohs
I use my DVD writer and DVDINFOPRO to get the info off of blank +R and it works everytime.Nero CDSpeed and Lite-On SMART-Burn Media check also work.Originally Posted by noki
www.cdspeed2000.com
http://www.liteonit.com/ODD/english/...n-f.asp?show=4
That's a recycling symbol. The 5 and PP tell us that theOriginally Posted by beyondgoodandevil
spindle's made of the plastic resin called polypropylene.
Can you please tell me how to compare my burned discs with the original files? I'd like to test that as well. FYI, I burned 50 DVD-Rs of the Memorx and no coasters. Burned all at 4X as well. Just picked up another 50 pack today and burned the first 13 with no probs. My DVDs are not larger than 4GB tho' which is where a lot of people reported problems.Originally Posted by davideck
Got a spindle of -Rs yesterday. Burned 3 at 4X so far without problems with SONY DRU500AX. We'll see...
harpe025 - I use DirToolKit, which has a binary file comparison utility. Ulead DMF2 leaves the Video_TS directory intact after a burn, so I just compare the contents of that directory with the actual DVD.
How is it you can still buy dual core pcs at bestbuy?
By yoda313 in forum ComputerReplies: 26Last Post: 1st Jul 2010, 17:06 -
Best Netbook available at BestBuy
By ryangarfield in forum ComputerReplies: 6Last Post: 1st Jun 2010, 22:34 -
2 Good 2 be True? Amazon Memorex DVD+r DL 50pk deal
By terryj in forum MediaReplies: 9Last Post: 10th Dec 2009, 11:00 -
Memorex DVD-R $9.99 50pk at BJ's
By MrMoody in forum MediaReplies: 5Last Post: 13th Nov 2007, 02:31 -
Memorex 2.4x DVD+R DL 50pack $19.99 at BestBuy
By dmagic1 in forum MediaReplies: 4Last Post: 3rd Oct 2007, 21:00
