Hello, i have a gateway with rambus memory. I see on advertisements for it that you can get ecc or non-ecc, what does the ecc stand for? I am looking to put more ram in my system, but i want to know if it matters about the ecc thing. thanks
Thread: Question about rambus memory
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at http://www.dvdrhelp.com/forum/viewtopic.php?t=187078
ECC stands for Error Checking and Correction.
It uses parity.
There is a parity bit that stands for if the value of the data is even or odd and the data value has to match the parity bit. If it doesnt then there was an error in the memory.
It is used in servers and workstations because of the need for data integrity but otherwise non-ECC is used (Business/Home Desktop systems). No real need for it. Plus it is slower and more expensive.
Not sure but your motherboard has to support it I believe.
Thanks piccoro, most likely my machine uses the non-ecc. i have noticed that there is a huge price difference between the two, i just wish i didn't have to use it. too exspensive.
Memory upgrade question
By zzyzzx in forum ComputerReplies: 12Last Post: 13th Jan 2011, 17:27 -
Question about Installing Memory to my MotherBoard
By hellfire45 in forum ComputerReplies: 7Last Post: 24th Sep 2010, 22:06 -
rambus mobo question
By slegh in forum ComputerReplies: 8Last Post: 4th Nov 2009, 20:07 -
ECC pc133 memory question....
By rubberman in forum ComputerReplies: 10Last Post: 7th Sep 2009, 15:26 -
MKV Question (need memory jogged)
By Maikeru-sama in forum Video ConversionReplies: 5Last Post: 29th Jun 2008, 12:49
Statistics
Newest guides
Latest tool updates
New media comments
