Hello all,
I capture/convert Hi8 video footage to DV AVI format with the
Canopus ADVC-100 product. Which luminance setting should I
use in CCE when converting to DVD MPEG2?
0-255 or 16-235?
Thanks,
vcddude
If for NTSC TV, then use 16-235.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
Thanks!
vcddude
dv is already 16-235 -- don't clamp it again ...
Depends on the DV codec and other intermediate processing steps you do before you hit the encoder. Try 16-235 first and if blacks look blocked up, and whites look washed out, and everything in between seems a little too contrasty (I think this is what should happen) then try the other setting.
One way to check your codec output is to open your file with AVISynth and use the ColorYUV(analyze=true) command. This will tell you the luminance range of the video after it passes through the DV codec.
yes true -- there are some rare cases were dv would not be clamped .. most of the time it would be though ..
BUT - important // do not go on what you see on your PC monitor as it WILL look "bad" (clamped video - where black will NOT look black) , only go by what you see on your TV (where black is black) ..
BUT
if you have a rearscreen projection tv (some of them), plasma display, video projector -- you do NOT need to clamp your video at all .. in fact it looks better not to .
do a test"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Thanks for the tip. Yeah, that's why I was specific about my use of the Canopus ADVC-100 in this context -- was hoping someone would know the answer in the context of the ADVC-100.
vcddude
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum CapturingReplies: 32Last Post: 11th Mar 2011, 18:55 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum CapturingReplies: 4Last Post: 28th Feb 2010, 01:23 -
CCE Luminance setting -- clarification needed
By eclipse95 in forum Video ConversionReplies: 14Last Post: 30th Sep 2009, 10:12 -
ADVC-300 vs. ADVC-100
By DeadLily in forum CapturingReplies: 11Last Post: 19th Sep 2007, 08:15 -
What Luminance level should I used with CCE?
By mlong30 in forum Video ConversionReplies: 5Last Post: 19th Jun 2007, 10:13
