VideoHelp.com Forum
Results 1 to 12 of 12
    I was wondering if anyone could help me out here. I bought a cake of 4X DVD's (or so I thought). I put one in my Optorite DD0203 and Nero 6.0.0.19 will only let me burn at 2X. I haven't burned any discs and I'm tempted to return them because I feel cheated. After using DVDINFOPro to find out what type of discs they were, I find out that they are Princo. Had I known, I wouldn't have bought them. The media information for every disc (I had to read them all) spit out the information below. Is it possible to get these discs to burn at 4X or should I take them back because they aren't 4X?
    Media Information
    Region information N/A not a DVD-VIDEO
    Media code/Manufacturer ID PRINCO
    Format Capacity Not Formatted
    Free Blocks 411107328
    Free Capacity 4.38GB(4.71GB)
    Book Type DVD-R
    Media Type DVD-R
    Media Id Code Speed 4.0x 5540KBps
    Available Write Descriptor CLV 1.0x 1385KBps
    Available Write Descriptor CLV 2.0x 2770KBps
    Write Strategy Speed 4.0x 5540KBps
    2x Speed OPC beta 09
    2x Speed OPC power 13
    2x Write Strategy field 1 11 87 78 80
    2x Write Strategy field 2 88 80 00 00 00 00
    4x Speed OPC beta 01
    4x Speed OPC power 1B
    4x Write Strategy field 1 0D 0F 0B 08
    4x Write Strategy field 2 97 08 0F 0C
    4x Write Strategy field 3 00 00 00 00
    4x Speed OPC beta multi-pulse 00
    4x Speed OPC power multi-pulse 00
    4x Write Strategy field 4 00 00 00 00
    4x Write Strategy field 5 00 00 00 00 00 00
    4x Write Strategy field 6 00 00 00 00 00
    Data area starting sector 30000h
    Linear Density 0.267um/bit
    Track Density 0.74um/track
    Number of Layers 1
    You paid for 4x and did not get 4x and you are wondering if you should return them? Of course you should. It may have been an honest mistake.
    Hello.
    Well, the reason why I ask for an opinion on this is because the write strategy on the media is 4X. I'm not that saavy when it comes to what should show on a 4X disc and I figured I'd ask.
    This is why I recently quit using Princo. The 4x would even fail at 1x. Bad balance.
  5. I recently bought a stack of Liquid Video 2x DVD-r discs from Cicuit City. I found they would not burn at 2X only 1X. So I checked them in DVDinfopro and found them to be
    Media code/Manufacturer ID OPTODISCK001
    Free Blocks 412352512
    Book Type DVD-R
    Media Type DVD-R
    Media Id Code Speed 1.0x 1385KBps
    Write Strategy Speed 1.0x 1385KBps
    Number of Layers 1
    Whats the deal did they lie about the speed its clearly printed on the disc 2X. Or am I missing something.
  6. I am having the same problem with a 50pack of 4x princos i just bought from directshoponline.com/meritline.com. Labeled on package and discs and dics info as 4x, but only burn at 1X or 2x in some cases. I had had great results with a pack of 1X before, so went with these 4Xs. In fairness, i have gotton an email response from the vendor wanting to ask me about durner firmware/etc. So I might get the problem resolved. IMHO, be wary, go with RITEKs when possible
    While I find this burn throttling happens more on Princo than any other disc my experience places certain burners at blame too. I burned 30+ DVD-R Princo discs on a Sony DRU-500A and NONE burned at 4X, all 2X. In my case I found the Sony would not burn any DVDs at 4X. Have you tried any other brands of media? Are you using a Sony burner by chance?
    It depends on the Firmware in the Burner, I could not burn Princo's in my
    LG 4040b at 4x, but with the firmware update, they all burn perfectly at 4x,
    and no coasters.
    LiteON are probably the best at "firmware updates" for different media.
  9. I have a PIONEER DVD-RW DVR-106D
    firmware reversion 1.05
  10. Originally Posted by bipartite
    It's a well known fact that the Pioneer only burns Pioneer certified 2X discs (such as TDK, Maxell brands) at 2X, but you can download a hacked version of Pioneer DVR-106 v1.07 RPC-1 + 2xDVD-R + 12xRip firmware from the following website:
    http://pioneerdvd.rpc1.org/
  11. It's a well known fact that the Pioneer only burns Pioneer certified 2X discs (such as TDK, Maxell brands) at 2X, but you can download a hacked version of
    This might be relevent if the original poster was referring to 1x or 2x disks, but he was referring to 4x disks.
    You didn't get ripped off. Those disks are known to do that in some burners. They are inexpensive but you may have to deal with 2x speed and possible compatibility problems. For faster and more reliable media, you have to pay more.
  12. Member rkr1958's Avatar
    I have a DRU-500A and I'm burning TDK DVD-R 2x at 4x using NERO. The resultant discs play well in my standalone player. I have firmware 2.0f.
  1. This Old Princo
    By hech54 in forum Media
    Last Post: 16th Oct 2009, 17:01
  2. Norton Anti-Virus: I Think I Have Been Shafted
    By Tom Saurus in forum Computer
    Last Post: 21st May 2008, 18:11
