VideoHelp.com Forum
  1. Member rkr1958's Avatar
    I'm in the process of a motherboard, CPU, memory upgrade and I'm thinking about getting the Intel - D875PBZLK motherboard and chipset. This motherboard has SATA150 (1.5Gb/s) (2 ports) RAID 0 Support7 and ATA100/66. I currently have only IDE ATA/100 HDs. Can I run this system with and boot from the IDE HDs? Can I run this system without any serial ATA HDs for the moment?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Not familiar with that board, but the one I use has SATA and RAID and I boot from the regular IDE bus. I shut off the SATA in bios, but that is probably not necessary. You can generally set up the bios to boot from almost any drive hooked to the MB. To really answer your question, you may be able to download the MB manual from Intel, which is a good idea anyway before you spend money on the board. Another good source for MB information is http://www.motherboards.org/ or do a Google search.
  3. There are IDE to SATA adapters as well as SATA to IDE adapters.
    You could get the one you need if you wish/need to place them on one of the 2 SATA controllers
  1. Replies: 8
    Last Post: 3rd Dec 2011, 01:06
  2. Replacement for dead Panasonic / Matshita UJ-220S with ATA interface
    By Persistence in forum DVD & Blu-ray Writers
    Last Post: 21st Feb 2010, 09:53
  3. Serial ATA hard drives on dvd recorders ?
    By joecass in forum Newbie / General discussions
    Last Post: 14th Jan 2009, 17:32
  4. Optiarc DVD RW AD-7530A ATA Device Burning problem
    By Yooki in forum DVD & Blu-ray Writers
    Last Post: 14th Jan 2008, 01:06
  5. 3 HDDs one PC... two ATA, one SATA
    By chewie8008 in forum Computer
    Last Post: 25th May 2007, 00:14
