    I'm looking for a bargain. I need to capture my old videos again (because I just founbd out the edited ones are out of sync! ). Well, now I own a MicroDV so it won't help much.
    Do you know if there is something I can use to transfer them to my PC?, do I need a camcorder? I', thinking buying one on ebay, the cheapest one to do the job (around 100-150).
  2. Bummer - I am doing a bunch of 8MM DVDs - but I bought a Sony TRV350 Digital 8 for the job - $450 at best buy - also does firewire inout to PC.
    I want to buy something used, for around $100 to $150. i'm watching some on ebay, so I hope I can get something cheap.
  4. Get Slack disturbed1's Avatar
    Cannon has a couple of new HI8 models that should run $150-$170. I picked one up on a clearance rack for under $150.
    disturbed1, where did you find the canon camera for $150?
  6. Get Slack disturbed1's Avatar
    It was the ES75 which was on clearance for under $150 at Meijers. Of course sold out now.
    Really a great buy. I compared it to my uncles "cheap" $450 miniDV camera, and there wasn't any video quality difference between the two, the miniDV cam did have better audio. MiniDV is easier to transfer though.
    Here's one for $169.
    http://store.yahoo.com/etronics4less/caeshi8cawic.html
    I'm really looking for a digital8 camera, also must be compatible with hi8. Do you know another brand besides sony, that sells D8 camcorders?
  8. Get Slack disturbed1's Avatar
    Hitachi, and Samsung also have D8 models.
    Cheapest I've seen is a Sony DCR-TRV140 for $260.
    A bit pricey, but this is a good solution too
    http://electronic.mainseek.com/P-B00...o-Walkman.html
  1. Reading 8 mm and HI8 tapes in Digital8?
    By tentate in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 28th Dec 2009, 10:58
  2. Replies: 2
    Last Post: 16th Apr 2007, 20:01
  3. Vedio8, Hi8 to Digital8
    By kinlunyu in forum Capturing
    Last Post: 5th Dec 2002, 01:41
  4. hi8/digital8 tape to CD/DVD master
    By marrsfamily in forum Capturing
    Last Post: 2nd Aug 2002, 16:09
  5. What is the resolution of 8mm, Hi8, Digital8, and DV
    By swoloschek in forum Video Conversion
    Last Post: 5th May 2002, 17:17
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
