Is there a program which allows one to play 2 videos side by side for comparison? I haven't decided whether to encode a divx into 2 or 3 svcds. If 2 svcds, then the bitrate would be around 1700, and if 3 svcds, the bitrate would be up to 2530. However, I encoded 2 samples of exactly the same clip with different bitrates, and I would like to be able to play both at the same time with the same settings so I could compare the 2 clips to see if the bitrates make a difference.
Playing one clip, then loading another clip isn't helpful because I can't "remember" all the details of the previous clip.
Thx
Results 1 to 13 of 13
Take a screenshot.(?)
Hey, Bottle, he said to play them side by side.
Hello.
I just opened Win Media Player twice and played 2 different movie files at the same time, side by side.
Both looked as good as one event does,so I don't think CPU utilization would keep you from doing that.
Give it a try with your preferred player.
Probably have to use the files from the drive, maybe CD and DVD-ROM if they are already burnt, but they might have to be on different IDE channels, or the drives will take turns reading.Might not be a prob, also might.
Cheers,
George
I'm thinking of doing this when I get my new camcorder. I'll shoot the same scene with both cameras. Since I'll be using DV-AVIs, I'll fire up Premiere and put one clip in the track above the other one. Then I could either crop the top one, or use a track matte to overlay half of the top video onto the bottom video. This should give a nice side by side comparison.
I don't play with Divix, so I don't know what editor will work with them.
I don't know if this might work, but you may be able to open one clip in PowerDVD and one im Media Player.There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
AviSynth can render them side by side as well. Just make take a few moments to get the chance to see them both together.
Hello.
sorry wrong button
No you do not "haft" to explain anything to me. A screenshot will only show two screencaptures. The two videos will not be playing side by side. If that were the case, I could save a bundle by looking at a poster rather than going to a movie.
Hello.
I tried this but WMP just keeps the same window open and closes the other video that is playing. I thought there was an easy way around this but I can't remember what it is.Originally Posted by gmatov
P.S. I think I saw "Bugster" talk about comparing videos side by side in a number of other threads. He may know a technique...
AviSynth can run four videos at the same time. Guess no one is listening. Pity.
Hello.
How? Do I serve them into two instances of virtualdub?Originally Posted by Tommyknocker
Hay guys, look at the dates on this post. I made the same mistake myself. I don't know how I got on this thread awhile ago, but I did. I posted before I seen what thread it was, then changed my post.
I don't know what happened but this is an old post we're on.
Not exactly. You open four videos at once in AviSynth. Have Virtual Dub mod render the video script to a separate filename. When it is finished, the new video will run all four videos at once. This code assumes all four videos are in the C: root directory. It will run in a 720 x 480 window:Originally Posted by Fmctm1sw
Code:q1=AVISource("c:fmctm1sw1.avi").BicubicResize(360,240) q2=AVISource("c:fmctm1sw2.avi").BicubicResize(360,240) q3=AVISource("c:fmctm1sw3.avi").BicubicResize(360,240) q4=AVISource("c:fmctm1sw4.avi").BicubicResize(360,240) l1=StackHorizontal(q1,q2) l2=StackHorizontal(q3,q4) StackVertical(l1,l2)Hello.
Player to play 2 separate videos side by side for 3D effect ?
By andy15star in forum Software PlayingReplies: 9Last Post: 21st Jan 2012, 12:52 -
Combine 2 Videos Side by Side
By bseos in forum EditingReplies: 7Last Post: 19th Jun 2011, 11:34 -
Comparing Encodes - Playing Two Side By Side?
By Brent.M in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2010, 18:31 -
Device for 2 videos side-by-side on TV?
By ehusted in forum Portable VideoReplies: 10Last Post: 18th Nov 2009, 01:10 -
compareing 2 videos side by side in same video. (sugestions)
By tessa101 in forum EditingReplies: 4Last Post: 9th Jan 2009, 02:36
