VideoHelp.com Forum
  1. I use VCD cutter or IRFANview to make snapshots from VCDs( Dat files)
    But I dont seem to get it working with WMV or asf format files.
    Can someone please suggest how to make a snapshot(jpg) of a WMV/asf file?
  2. Google "Printkey 2000 v5.10" it is a general screen capture program that will let you crop and save to jpeg. They have a freeware version of it.
    Just one easy way to do it.
  3. Thanks Suntan for the reply.
    But won't it capture the entire desktop instead of the clip itself ?
    If that one doesn't work the way you need, there are loads of free screen capture apps available.
    Sometimes the only trick with video is you need to disable hardware acceleration temporarily while you do it.
    There was a thread recently with lots of progs mentioned and ways to do it. Try a search upper right corner for "screen capture".
    Good luck.
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
  1. Codec problem in ASF/wmv file (wvc1)
    By ezzeee1 in forum Editing
    Last Post: 25th Feb 2011, 20:16
  2. Convert from wmv/asf to mp4 - results in zero length file
    By techiejustin in forum ffmpegX general discussion
    Last Post: 25th Apr 2010, 22:56
  3. Replies: 3
    Last Post: 11th Nov 2009, 13:19
  4. Converting an ASF (WMV) file
    By yadda in forum Newbie / General discussions
    Last Post: 7th Nov 2007, 06:16
  5. May I know which software can convert a wmv or asf file to better viewable
    By sniper in forum Newbie / General discussions
    Last Post: 6th Aug 2007, 12:22
