Hi all,
Can someone explain how to re-author a supposedly non-compliant VCD using VCDEasy?
I have some VCDs that won't play on my DVD player, while I have others that will play and someone suggested that the VCDs that cannot play are not compliant...
Thanks for your help.
Isobuster will rip the .dat-mpegs from the disks and return them to standard mpeg files. Look in the "Guides" for directions. You can then re-author, just drop it into VCDEasy and burn. If that doesn't work you may need to re-encode your mpeg to standard VCD spec, TMPGEnc can do that. The guides section will help there too.
Thanks for the suggestions. I'll download the programs and try it out.
Author VCD files in a to DVD Disc
By akakiami in forum Authoring (DVD)Replies: 6Last Post: 5th Jan 2009, 05:22 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 06:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 10:46 -
How To Batch Author Compliant DVDS - The Easy Way
By Dilemma in forum User guidesReplies: 12Last Post: 2nd Jan 2008, 03:28 -
Help:How to author 3 disc vcd movie into single dvd without reencoding
By devstallion in forum Authoring (DVD)Replies: 6Last Post: 31st Dec 2007, 03:40
Statistics
Newest guides
Latest tool updates
New media comments
