VideoHelp.com Forum
  1. Hi ,
    I have a number of short DVD movies converted by DVD2ONE - each around 1.3 GB in size in the respective VIDEO_TS folders. I would like to put 3 of these short movies on one DVD but need some help on how to do this.
    How do I join / author these and what's the best utility to combine these on one individual DVD?
    Thanks in advance
    If you have an authoring program that will work with VOBs directly, you can use that and author your DVD by just using the VOB files. The ones that I know will do this DVD-Lab and TMPGENC DVD Author. There are probably others, but I do not know them, and I'm sure others will chime in.
    If not, I think that there is a guide on this site that uses IFOEDIT to merge multiple VOBs together into 1 titleset. That might also help with what you are doing.
  3. Member jaxxboss's Avatar
    Ditto on DVD Author. Just add the vobs (add file) works great and is easyyyyyyyy.
  4. Many thanks!, Got a 30 day eval of DVD Author and it did the job.
    Cheers.
  1. Replies: 11
    Last Post: 23rd Jan 2010, 17:10
  2. Master Menu For Multiple Video_TS Folders
    By MourningStar in forum Newbie / General discussions
    Last Post: 17th Jun 2009, 13:38
  3. AVI to DVD not outputting Video_TS or Audio_TS folders
    By threesixes in forum ffmpegX general discussion
    Last Post: 30th Dec 2008, 01:23
  4. How do I rip DVD to VIDEO_TS/AUDIO_TS folders?
    By Crimea in forum Newbie / General discussions
    Last Post: 18th Feb 2008, 11:34
  5. how do install two folders video_ts in one dvd-r
    By togood in forum DVD Ripping
    Last Post: 13th Dec 2007, 05:58
