Hello All,
After testing vcdeasy with succes I bought the commercial version 1.17. Now I try to make a vcd with still pictures which are converted to mpeg exactly as described in the manual 'How to make a still pictures VideoCD (v1.1.6)'.
I also added a menu still picture with 7 entries. Total 1325 pictures and 1 menu picture. I did everything according to the manual 'How To Make a Still Pictures VideoCD With Menu (part 1) (v1.1.6)'
After hitting the GO button I first have the message that the creation of the XML file is succeeded. After that I get the error message 'vcdxbuild.exe execution failed. Too many files/directories in the iso9660 part of the video cd. A video cd has a small table of content for the iso9660 files.'
So I only get a xml file and no vcdbuild.exe or cue/bin files or whatever. I cannot find any details on the internet about this errormessage.
Can somebody help me ? What am I doing wrong? All the settings in vcdeasy seem to be correct. It uses nero aspi.
Thread: vcdxbuild exe execution failed
Greetings
Paul
I also have got this error message!
Please, need support on this!
I have tried uninstalling a lot of programs.. and still I get this message.
Error message like this;
writing track 1 (ISO9660)...
'update scan offsets' option enabled for the following tracks!
writing track 2, MPEG2, NTSC 2/3 D1 (480x480/29.97fps), audio[0]: l2/44.1kHz/192kbps/stereo ...
7 [main] vcdxbuild 1040 handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
14512 [main] vcdxbuild 1040 open_stackdumpfile: Dumping stack trace to vcdxbuild.exe.stackdump
[48s 320ms (VCDxBuild.exe)]
My problem is fixed in the meantime thanks to the excellent support from the VCD-Easy guys.
It appears that one should NOT add too many files in the ISO file system part of the VideoCD. This is a mistake in the manuals, where was stated that one could store the picture original files on the same VideoCD. I stored about 340 jpg files on the same CD. A videocd can not hold so many files in its ISO file system part... because of the VideoCD specifications was explained to me.
You can store a few files, but not so many as I did. After I deleted the jpg files in the ISO file system part, I could burn the vcd without any problems. After that I burned many more, its working very good and fast.
The guys from VCD-Easy promised to modify their manuals on that point.
Reading the error message you have, I am not sure whether you have the same problem I did.
ByeGreetings
Paul
Actually this problem your describing hasn't been the issue..
I added 1 large 750Mb mpeg file.. and tried to make a SVCD movie.
It failed.
Then I tried to add a smaller mpeg file, and it was OK.
So I guess there where something wrong with the file size..
Although - vcdeasy has managed to handle such large files before.
AviSynth: script command, order of execution, and 'coding efficiency'
By hollowman in forum Newbie / General discussionsReplies: 6Last Post: 27th Aug 2008, 23:44 -
VirtualDub problem - error during script execution
By ineedhelp123 in forum Video ConversionReplies: 17Last Post: 31st May 2008, 07:29 -
Data Execution Prevention
By DuBsTaR in forum ComputerReplies: 9Last Post: 25th May 2008, 12:49 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 08:42 -
DivX Player crashing immediately upon execution
By Neptuna_Fish in forum Software PlayingReplies: 3Last Post: 19th Jun 2007, 14:29
