VideoHelp.com Forum
Thread: DC30?
  1. Can the DC30 make MPEG or DIVX video instead of MJPEG. I want a compressed file not uncompressed. So can anyone help me? Thnx.
    Nope.
    You must use the Pinnacle codec to capture, what you do after that is up to you though.
    If you have a fast enough disk system, you can cap at very low compression 3:1 I believe is the least compression.
  3. 3.0:1 is the lowest compression on the DC30
    Adam
  1. upgrading to DC30
    By jmacky in forum Authoring (DVD)
    Last Post: 25th Oct 2009, 21:18
  2. DC30 capture problems
    By jaybird in forum Capturing
    Last Post: 15th Apr 2009, 14:11
  3. MJPG miro DC30 best bitrate VHS to DVD
    By dav75 in forum Capturing
    Last Post: 13th Sep 2007, 05:36
