Burner: Pioneer A05
DVD Player: Panasonic DVR31
Media: MXL G01 (maxell)
I burn a dvd image, using DVD Decryopter, now when i play it in my player the video sometimes like sorta freezes and keeps going, and audio sometimes just not there for like 1/2 a second. Its not that bad, it happens every 5 minutes, sometimes every 1 minute, sometimes doesnt happen for like 10 mins, sometimes audio is gone for like 30 seconds.
Is it the media? the player? the burner?
The DVD Plays fine in the Pioneer A05 DVD Writer.
Thanks.
You can use the info on this site to do a little investigating.
Look up your Player, Burner and Media on the left (under OTHER). See what combinations others have found works for them.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
Then it probably the media. You may want to try to burn at a slower speed, as it sometimes helps. If that doesn't work, give changing the media a shot.
Hello.
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
Need some help with "dubbing"/"muxing" video with audio
By FSSSWE in forum Newbie / General discussionsReplies: 9Last Post: 21st Jun 2008, 18:49 -
Aspire Digital AD-8091 DVD Recorder "skips" when records programs
By ray2000 in forum DVD & Blu-ray RecordersReplies: 16Last Post: 14th Feb 2008, 08:57 -
Editing self-owned dvd movies to make "clean versions" for my fam
By nef1l1m in forum EditingReplies: 5Last Post: 1st Aug 2007, 14:00 -
Burning my first DVD home movies with Pinnacle, "disc error" on D
By tony777 in forum Authoring (DVD)Replies: 2Last Post: 13th Jul 2007, 21:07
Statistics
Newest guides
Latest tool updates
New media comments
