VideoHelp.com Forum
  1. i have used a few programs and have had no success...i just converted a movie for over 2 hrs using tmpge and easy cd creator wouldnt recognize it....i converted the audio first..the file became 1.5 gig pcm.avi and i couldnt burn it to create a video cd. is there anyone out the that can help me....?
    thanks,
    lank-e
    First of all, load TEMPENC, out of all the options select "SYSTEM", then click LOAD and select the template you want to use to encode. Select either PAL or NTSC VCD compliant MPEG.
    It should then burn OK. However, I think the fact that your AUDIO part is 1.5 GIG means you are doing something very wrong during the encoding process.
    You should always encode using SYSTEM, this encodes audio and video together.
    I can't think of what you are trying to encode, unless your trying to rip DVD then that is a different problem, and a waste of time in mmy humble opinion.
  3. Did you use the tutorial off of here? If you do, it should work.
  4. Are there curtain avi files that wont work with TMPGEnc?
    eg.
    I have (IND)SWORDFISH.CAM(1OF2).AVI and when i use TMPGEnc all I get is a sound but no picture even tho it converts the whole thing.
    But
    when i use [vv]swordfish.cam.hbovcd.divx.avi I have no problem converting it to VCD mpeg format.
    Is this because its a divx?....I don't know if the first one is one too.
  5. It might have something to do with the divx codecs you have installed.
  1. Isnt VCD obsolete?
    By omega_weapon in forum Authoring (VCD/SVCD)
    Last Post: 20th Nov 2010, 12:51
  2. ogm file with subtitles isnt working
    By dudeboy in forum Mac
    Last Post: 5th Sep 2009, 07:53
  3. Problems converting AVI to vcd format using TMPGenc 2.5 Plus
    By peterock in forum Video Conversion
    Last Post: 28th Dec 2008, 15:34
  4. Replies: 0
    Last Post: 12th Aug 2008, 19:11
  5. Problem converting avi to vcd using CCE
    By Hittz in forum Newbie / General discussions
    Last Post: 2nd Dec 2007, 20:27
