Hello! I have created a DVD using Studio 8 and have burned it using Nero onto DVDR (general purpose purple-colored discs). I picked UDF/ISO and 1.02 and did NOT relax any settings. I have also used the DVD Video setting in Nero V 5.5 to burn as well. Both attempts always play in my dvd player which I bought specifically so it can play DVDR and DVDRW. My older player (Toshiba dual disc player) just says DISC ERROR when I load the DVD.
I know not all players support DVDR but I have since tried to sell my authored DVD to customers who are NOT able to play them on their DVD players. Some just bought them within the last year or so. It plays on both of my cheap players I bought being Toshiba SD3900 ($79) and the LANDEL brand ($39) from Frys.
Now, is there something I can do to make my DVDR more compatible with older players or just more compatible? Since it works in my 2 new players ( I researched and made sure these 2 played DVDR and DVDRW), then is it that the other players just don't support these formats?
I also backed up a commercial DVD using Decrypter which played great on my 2 cheap players but it got the DISC ERROR on my older Toshiba player. Is this something that is a fact and have to live with it?
Is there something that I can do to make it readable on those players that can't read it? Am I doing something wrong?
Please advise. I need to reauthor/burn if I can make it more compatible. Thanks in advance.![]()
Results 1 to 30 of 36
Thanks and regards,
RayBan
ATI 9600 Pro; Abit BH7; P4 2.4Ghz 533; 1G PC2700 DDR; Toshiba SD5002 DVDR; WD 120G 8MB 7200 Capture Drive & 160G 7200 Program Drive; Pinnacle Studio 9 and Nero6
Run the VIDEO_TS folder through INSTANT COPY (Only takes around 7 to 10 minutes) which will then generate an image file which IC will burn direct to DVDR.... Trust me on this one.... it really works.
Your completed DVDR will play on alot more players (Please dont ask me how it does what it does) FFWD at full speeds without frame freezing, moves back and forth to chapters much quicker.... Either way, its worth a try...... "Works for me.... and alot of other people I Know"
Paul (UK)
Will this help me as well??Originally Posted by kv5
please see this post:
http://www.dvdrhelp.com/forum/viewtopic.php?t=183430
Also is there a guide for INSTANT COPY
There are a lot of things that effect compatability. It is not easy to get 100% playability. I'm currently gettin 100%. I am the oficial video dude for my son's Baseball and Football teams. I distribute DVD copies of the games to parents. I've distibuted to over 75 different customers with no playback problems whatsoever. There may be other ways, but this is what really works:
1st, if you have a -R or a dual-format burner, just sell it! Get a +R that lets you change the bitsettings(like a Ricoh 5125 or 5140). When you burn the video in Nero, make sure you select DVD-ROM for the booktype.
You also need to make sure the dvd files are comliant. These are the methods I use, but your results may vary:
Video = Premiere > Mainconcept encoded @ 8000 kbps(CBR).
Audio = AC3 encoded with Beesweet @ 224 kbps.
DVD = Authored with DVD-Lab
Burn = Burned with Nero with DVD-ROM booktype.
Disks = Fujifilm or TDK DVD+R(witch ever is on sale)
Use what you want, but my methods work.There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
Where does one choose booktype in NERO??? Also I am using Shrink.
Originally Posted by racer-x
dudeman316,
Check this guide http://www.dvdshrink.info/nero-video.php
It will tell you how to use DVD-Video but you will know how to select
DVD-ROM as well.
racer-x,
I tried to use BeSweet to generate AC3 audio for my home video and
authored it with DVD-Lab (also tried tmpgenc dvd author) but
there is no audio in the resulting dvd. Burned with Nero.
Can you pls explain who you extract audio and convert it with BeSweet.
I followed a guide posted on this site on converting wav to ac3.
The best way to make a recordable more compatible:
send it to a pressing plant and have a real DVD manufactured. You may have to pay a couple grand and get a minimum run of 500 or 1000, but they'll work!
use stomp's RecordNow. I used Nero to burn DVD's but they won't play in many standalones. However a few friends advised on the net to use this, I have and have greater compatibility
Hope this helps
Tom
Lal thanks so much for the Guide I have figured it out. The DVD-ROM booktype worked. Now my next question:
I have the back to the future triology. I have successfully backed up the main movie files with mneus using DVD Shrink, but i however had to make the extras still images. IS there any way I can make a forth disk with nothing but extras? If so what programs would I need or could someone point me to a guide please. And thank you all for your replies & help.
lal wrote:
I don't extract anything, it's all my material.I tried to use BeSweet to generate AC3 audio for my home video and
I don't know what video editor and/or encoder you're using, but you need to output the MPG to seperate streams(M2V and PCM wav). You need compliant PCM wav @ 4800 mhz. You should use a good audio editor(like CoolEdit Pro) to check the PCM wav file. You can upsample it to 4800 mhz if you need to.
I use the guide on this site to convert the PCM to AC3 @ 224 kbps.
If you use DVD-Lab, you need to make sure that all audio is the same format. If you use AC3 on the video, then even the menu background Audio should be AC3.
I've never experienced Audio problems with my methods, so I can't help you any more than I have.
Good luck!There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
And DVD-R will play on older sets while DVD+R will not.
The original poster has a minus writer so this is a bit off-topic butOriginally Posted by jdizzy40
http://www.dvdrhelp.com/forum/viewto...=683738#683738Originally Posted by Buck9419
While a DVD-R has better standalone compatibility than a "plain" DVD+R,
DVD+R(W) with DVD-ROM booktype on a good media is a never fail.
Ask any Ricoh(type) owner....You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Can someone please explain how burning in DVD-ROM setting in NERO is different from just using NERO Express or the DVD writing tool I'm using in TMPGEnc Author? I followed the guide and used the DVD-ROM setting in my NERO program and it worked but what's the difference?
Also, is the DVD-ROM method more compatible?
Nero's DVD-ROM compilation is not related to booktypes.Originally Posted by Captain Satellite
Only Ricoh and Benq type burners are capable of bitsetting
So, what would the difference be between using NERO Burning ROM or NERO Express, being able to customize settings? Does this afeect compatibility?
There's two ways to burn movies in Nero
1. DVD-ROM(UDF/ISO)
exact settings here http://dvdshrink.info/nero-udf-iso.php
2. DVD-Video
exact settings here http://dvdshrink.info/nero-video.php
Nero Express uses the DVD-Video settings and generates the folders automatically, its foolproof.
For me both methods work....You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Thanks, Tom. In your opinion, will the Ricoh burner employing the methods described above, produce discs that are more compatible on a wider range of players? (Thanks for your patience)
I believe the answer is yes if I'm reading your response correctly here:
"While a DVD-R has better standalone compatibility than a "plain" DVD+R,
Ask any Ricoh(type) owner...."
What is the difference in the finished DVD using these two different methods?Originally Posted by tompika
Only God knows ....
(because AHEAD Software AG does not
@ rayban
Have you tried using Ritek disks ?
Use a good player, use good discs, burn compliant DVD-Video.
DVD-R does not have any kind of "booktype" change. That being said, realize it does not make DVD-R inferior, but simply allows DVD+R to have a compatibility nearer or equal to that of DVD-R.Answers to Common Video Questions:
Best blank discs Timebase Corrector FAQ Best VCR for capturing Help restoring video
Correct.Originally Posted by lordsmurf
Who said it does? I admit DVD-R doesn't need itDVD-R does not have any kind of "booktype" change.
I'm questioning that.That being said, realize it does not make DVD-R inferior, but simply allows DVD+R to have a compatibility nearer or equal to that of DVD-R.
Tell me about your personal experiences of testing different booktypes and their compatibility.
I just let you all know:
The new Nu-Tech 8xDVD+R, 4xDVD+RW burners write ROM booktype by default!
8xZ-CLV writing on 4xmedia.
And they are cheap!You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Several dozen DVD+R and DVD+RW with varied booktypes. Problems on DVD-ROM DVD+R same as DVD-R with players used on. DVD+R DVD+R compat sucked. Only exception is an altered DVD-ROM DVD+R didn't work on one player, only took DVD+R DVD+R and DVD-R and DVD+RW and DVD-RW. Variations of burning done too. Was test conducted with assistance of willing friend, over period of several months. One player took nothing. One took only DVD+RW and DVD-RW, no -R or +R. One only took DVD-R. Every time I saw a new player, I tested. Had a stack of discs, labeled with what they were. Think at this point in time, I have one left, tossed most of them or gave them away. Did this earlier this year. I think I tested 20 or more players.Originally Posted by tompika
That good enough for you? I do test things. Neither one is better, booktype changes can help, but not always.
I know you'd like to think it made it 100%, but it's not. Sorry. I'd change it if I could and invest in DVD+R myself, but that's not the case.
I could break it down for you on paper someday, but right now, I've got better things to do. Just trust that I tested thoroughly, those are the results.Answers to Common Video Questions:
You are right, I would love to see it "on paper" with all the details.Originally Posted by lordsmurf
I'm always interested in compatibility testings!
I guess this is the first time you mention this testing on dvdrhelp or lordsmurf.com
But I know you are very busy!You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
http://www.dvdrhelp.com/forum/viewto...=655401#655401Originally Posted by lurdsmurf
Oh yeah I do trust....
You love to pick on me don't you? :P
Not done, as in final results (easy to read stat analysis) not finished. One or two discs done recently to cap off studies, most discs done in past months, stats worked out in scribble now. But nothing makes sense to anybody but me, reading my notes. So it's still not REALLY done. It's done, but its not. Are you following?
Takes time to move notes into final statistics.
But at the moment, I've got other projecst to complete. Calm down, things come out of me as I find time.
And even then, there's two more test I just came up with, so this is a living test to be honest, never going to be finished with all the possibilities. I'll attempt to make stats eventually, hopefully in a format that I can update, another problem to compound time on it.Answers to Common Video Questions:
Right. I think I can follow you now.
When you say "TESTS HAVE NOT BEEN DONE" that later means
"Not done, as in final results, so it's still not REALLY done. It's done, but its not."
Wait, I think I'm confused again just like when you say you "had no player refused the Nero created discs" but two weeks later you post a thread: you did not count your old APEX1100 because you considered as junk but now it reads the discs created by TMPGEnc's burning engine.
Don't try to analyze words to much. We all have the right to reclarify as needed, and advice for all situations are based upon the information needed at the time. If I always included extraneous data, for the sake of avoiding potential argument, nothing would make sense.
The Apex case stands as it is (not considered a player by my terms of the argument due to reasons stated) and the DVD+R tests stands as a complexity unexplainable in detail at this time, only available in short summary. Take what I can give. If it's not enough, sorry. I'm sure if you dissect everything I ever written, you could make a lovely book of potential inconsistancies, typos, errors, conspiracies and a generally boring read. And I'm sure this goes both ways.
Do you also ask the doctor and dentist to explain so much? Wow. I can imagine you as the kid that sat and asked "why, why, why, why, why" without end. :PAnswers to Common Video Questions:
I want to make edited photos compatible with my digital camera again.
By Cyrax9 in forum MacReplies: 3Last Post: 30th Mar 2010, 00:09 -
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 15:10 -
Finalize vs. Make Edits Compatible
By UnknownVT in forum DVD & Blu-ray RecordersReplies: 0Last Post: 25th Feb 2008, 14:44 -
Software to make sure the audio and video of a authored dvd are in sync?
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2007, 07:13 -
How to Make Authored DVD INTO .ISO WITH TMPGENC DVD AUTHOR
By Chupes in forum User guidesReplies: 4Last Post: 19th Aug 2007, 17:38
