OK, I'm trying to add subtitles to a DivX with AC3 audio and convert it to SVCD. I used virtualdub and headac3he to extract and convert the audio to create a wav file, then used the subtitle filter in virtualdub to add the subtitles, and that was all fine.
Then I went to start frameserver and created the VDR file. That went fine too.
The only problem is that when I come to load the VDR file into TMPGEnc it says cannot open/unsupported. I can only assume this is because the DivX has AC3 audio, because I tried it with a couple of other DivXs which aren't, and TMPGEnc recognized them fine.
So has anyone else heard of it? If so, is there a way around it? Or is it just my TMPGEnc playing up?
Hello.
I've already tried that, and it didn't work. Thanks anyway though
What else have you tried, so I can quit wasting your time?
Hello.
If you made a separate wav file , you can load your video
in vdub and tell it - Audio -> Wav Audio. That will substitute
the wav for whatever is in the video. Then the VDR file has
wav audio.
Or click Audio->No audio before starting your frameserver. Use the vdr for video and the wav for audio.Originally Posted by FOO"Art is making something out of nothing and selling it." - Frank Zappa
None of that works
I think I'm just going to encode the DivX to MPEG, then run it through a second time to add the subtitles, being as I need to put it on SVCD by tonight.
try to frame serve via AVISYNTH
have to install (2.51 and then the 2.52)
then make a simple script in notepad and save as movie.avs (not text file)like this:
avisource("c:\path\divx.avi")
then in tmpeg open the movie.avs
this is just to encode video for audio try besweet or...
it must work
and you could add subs with the filter "vsfilter" (vobsub filter for avisynth 2.5x
AC3 Files with TMPGenc
By PHNeedsHelp in forum AudioReplies: 3Last Post: 4th Nov 2009, 12:37 -
Philips DVP5990/37 doesn't recognize *.divx extension
By picrade in forum DVD & Blu-ray PlayersReplies: 23Last Post: 7th Apr 2009, 13:07 -
Only TMPGenc Support .vdr
By arturjose in forum Video ConversionReplies: 1Last Post: 15th Apr 2008, 23:04 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
DivX player will not recognize subtitles
By jbhouse in forum SubtitleReplies: 1Last Post: 13th Nov 2007, 04:28
