I am trying to create a DVD-R with Ulead DVD Workshop SE. I generated a MPEG2-IBP file in Premiere 6.0, which produced a 2.9 GB avi video file, and a 900 MB WAV audio file. The video file has a duration of 1 hour 20 minutes.
My problem is that, when I import it in DVD Workshop, it will only read the first 55 minutes of the file and won't let me read the rest. However, when I open the video file in Media Player, it reads the full 1 hour and 20 minutes.
This is the second time this happens. I created another video that was about 2 hours, and only 55 minutes made it on the DVD.
I looked through the entire DVD Workshop help file, and on their knowledge base, but couldn't find anything on this.
Any help would be most appreciated.
Is it a 2.9gb .AVI file?Originally Posted by lfernando
Or is it a 2.9gb MPEG file?
Did you use the MainConcept encoder?
If not, which encoder did you utilize?
I sometimes work with MPEG files that have the following precise video/audio properties:
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 704 x 480, 29.97 fps
Field Order B
(DVD-NTSC), 4 : 3
Video data rate: Variable (Max. 8800 kbps)
Audio data rate: 256 kbps
MPEG audio layer 2, 48 KHz, Stereo
How do the specific properties of your source video/audio compare?
Jerry Jones
http://www.jonesgroup.net
IT is a 2.9 gb .avi file, NTSC, 24 Bits, 704 x 480, 29.97 fps.
My audio rate is at 48 Khz
I encoded the movie using the Matrox RT MPEG2 IBP encoder.
The program produces two files: one avi file and one wav file.
I encoded at variable rate, with a max of 6.0 mbps.
And today, I encoded a second file with the same specs. It has a duration of 1 hour 45 minutes in Premiere, and I see the full 1h45 minutes when I play the avi in Windows Player, but when I import it in DVD Workshop, I can only see 1:12 minutes.
I imported the file in DVDitPE, and I can see the whole file in that program. The problem seems to be with DVD WOrkshop.
Yes - the Matrox RT files are problematic with DVD Workshop.Originally Posted by lfernando
Ulead is aware of the problem.
Jerry Jones
What do you think??? Maximum Quality/Low File Size DVD conversion
By iqbal88 in forum DVD RippingReplies: 6Last Post: 7th Aug 2011, 02:48 -
Maximum bitrate for DVD with MKV file
By elmuz in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2011, 11:28 -
DVD recorder truncates recordings
By JosephWebber in forum DVD & Blu-ray RecordersReplies: 11Last Post: 4th Nov 2009, 10:49 -
Conversion from VOB-File into a MP4 File stopps after 9 minutes...
By Fly Eagle in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2009, 11:41 -
Does WinDV transfer a maximum segment length of 19 minutes, 6 seconds?
By VMiller in forum CapturingReplies: 5Last Post: 13th Jul 2007, 21:55
Statistics
Newest guides
Latest tool updates
New media comments
