VideoHelp.com Forum
    Q. Is it better to convert to DVD at high bitrate and then Shrink to DVDR or just use a lower bitrate to start?
  2. Member GKar's Avatar
    You can use a bitrate calculator which will get you close, or as I do, capture at higher bitrate then shrink using DVDShrink and get a perfect fit. The quality difference will not be that great though probably. You capture an AVI then convert, so your quality will be more dependant on your capture resolution in my opinion.
  3. Generally speaking it's best to use a lower bitrate to start with, then encode at a high bitrate and shrink. The reason is tha encoding produces superior quaility to transcoding (DVD Shrink, DVD2One, IC, etc). A multipass VBR encode at the correct bitrate should yeild better results, than a 8000kbit/s encode transcoded down to 1150kbit/s.
  1. Replies: 3
    Last Post: 27th Sep 2011, 05:56
  2. High Quality At Low Bitrate?
    By sanosuke in forum Video Conversion
    Last Post: 4th Apr 2010, 08:21
  3. Using mutiple passes with lower bitrate vs single pass with high bitrate on
    By jones24 in forum Newbie / General discussions
    Last Post: 14th Aug 2009, 18:17
  4. Low bitrate source to High bitrate target
    By sameerdhiman in forum Newbie / General discussions
    Last Post: 7th Nov 2008, 23:54
  5. Replies: 5
    Last Post: 31st Aug 2008, 20:11
