Hi there,
I am new here, and am trying to decide which dual format DVD burner to buy for our computer (meaning DVD+R/RW and DVD-R/RW). I have already purchased a stand-alone DVD recorder for the tv, which records on to DVD+R discs. I would like to burn copies of these discs for other people in my music trading group. I would like to know if the dual format DVD burners will copy a DVD+R disc to a DVD-R disc and vice versa. I have heard conflicting answers so I would like to know if any of you have tried it yet.
I need to be able to copy my DVD+R discs to DVD-R discs because some of my friends only have a DVD-R burner (which means they won't be able to copy a DVD+R disc for other people). Or they may send me a DVD-R disc that I may want to convert to DVD+R format. I hope I haven't confused everyone!
Thanks![]()
I've never had a problem copying DVD-R to DVD+R.
I usually use DVD Decrypter ISO read - ISO write functionsYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
If you have a dual-format burner, you should have very few problems.
One thing to consider, the DVD+R/W format has a few less bytes available overall than the DVD-R/W or RAM formats. Not a lot, but if you are wanting to do a 1-to-1 straight copy, and you've filled your DVD-R all the way to the brim, you'll hit a snag. This rarely happens, but it has come up on a few threads here before.
Thanks for your info guys!
Scott, you mentioned the difference in bytes between + and - discs. How many minutes of video would this equal approx, say if I recorded a disc in the 2-hour mode on a stand-alone DVD recorder?
Debbie
mrbass.org
Blank DVD-R 4,489MB 4,706,074,624 bytes or 4.383GB
Blank DVD+R 4,483MB 4,700,372,992 bytes or 4.377GB
6MB difference, a few secondsYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
right,
so it would rarely make a difference, except in cases where you "burned it to the brim". In that case, your choice would be to:
1. Split the material onto 2 discs
2. Shrink (transcode/transrate) the material to fit
3. Copy the material to HD, trim off some "unwanted" seconds, and burn to the other disc
4. Skip it, and leave it on the original disc only
I couldn't say just how tight set-top DVD recorders would burn discs, especially when a number of them use 1-pass realtime (buffered) VBR.
Hopefully, this won't have much of an effect on your situation.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 7Last Post: 26th Dec 2011, 16:18 -
dvd to vhs recorders and vice versa
By videohell in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th Nov 2011, 06:02 -
How to convert 5.1 to 2.0 AC3 and vice versa
By lapetite_66 in forum AudioReplies: 5Last Post: 8th Mar 2010, 19:30 -
How to convert fullscreen to widescreen and vice versa?
By coxanhvn in forum Newbie / General discussionsReplies: 7Last Post: 16th Jul 2009, 23:01 -
change avi from 16:9 to 4:3 and vice versa
By slowjoe in forum EditingReplies: 9Last Post: 6th Jun 2007, 07:11
