VideoHelp.com Forum
Results 1 to 11 of 11
  1. Hi
    I recently bought the ADS Tech Instant DVD 2.0 capture device. I transferred a 2 hour VHS tape to mpeg 2 using the capture wizard software that comes with the unit. It asked me what quality I wanted and I answered DVD.
    Ulead Video Studio 7 SE DVD & DVD Movie Factory SE DVD software also came with the unit. When I went to burn a DVD I could only fit 65 minutes of the video on to a DVD. I thought at DVD quality I could fit 2 hours worth of video on a DVD.
    What did I do wrong or is this normal? I have over 20 2 hour 8mm tapes I want to convert and I thought I could fit one tape on each DVD
    Thanks for any help
    Steve
    Use the bitrate calculator on this site (TOOLS) to determine what bitrate choose for what movie length.
    No guessing or assumptions allowed. :c)
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
  3. Member wulf109's Avatar
    You need a bitrate of 4500 to fit 2 hours on a DVD,but that assumes the is in ac3 or mp2 compressed format,if it's PCM the bitrate will need to be lower. Will your autoring program create a VIDEO_TS directory more than 4.37GB's. If it will you could compress that to 4.37 with DVD Shrink.
  4. Originally Posted by Gees
    Thanks I will definitely check it out. Will the video quality suffer a lot if I put 2 hours instead of 1 on a dvd? These are home movies and I would like good quality
  5. Will the video quality suffer a lot if I put 2 hours instead of 1 on a dvd?
    It depends on the encoder used.
    It also depends on the audio compression. the LPCM audio is very big, uncompressed or something like that. Better use MPG-1 Layer II audio
    so you can put higher video bitrate
    <steve84> An FYI...your source VHS tape (unless it's SVHS) is just above MPEG 1 quality...so just about anything you do to the DVD bitrate should preserve your video quality. Use AC3 though for your sound. 2 hours of AC3 sound should sit a little bit less than 200 megs...
    Originally Posted by petec
    <your source VHS tape (unless it's SVHS) is just above MPEG 1 quality...so just about anything you do to the DVD bitrate should preserve your video quality.
    Partially true.
    VHS= 220x480 or 240x480
    DVD can be 352x240 MPEG1 or MPEG2, which is lower.
    352x480 at 4.0 will yield perfect results and up to 3 hours of video.
    Use that only if you are in a PAL country. PCM or AC3 only for NTSC.
    Personally, for precious home videos I would not place more than 90 minutes/DVD. But that's just my preference.
    You can always try 2 minute segments with different settings as tests.
    I always write the DVD to harddrive first - RW disc second, then finalise on a + or - R disc.
    Good luck with it all.
  10. Thanks everyone for the great help so far. This board is great.
    One more question. The majority of the tapes I have left to convert are 8mm not VHS. Are the suggestions different for 8mm quality or is it pretty similar to VHS
    Steve
  11. 8mm & vhs are very low resolution.
    I use a Panasonic e30 dvd recorder, I can get 4 hours of video on one dvd & the quality is great. Actually better than the original if its from 8mm or vhs.
  1. Replies: 2
    Last Post: 21st Oct 2010, 17:51
  2. Replies: 5
    Last Post: 21st Sep 2009, 23:57
  3. Replies: 3
    Last Post: 6th Aug 2008, 21:23
  4. 6 hours of good quality video on dvd
    By gameroftheuk in forum Authoring (DVD)
    Last Post: 30th Aug 2007, 01:59
  5. What Is The Best Way To Fit 2 Hours On A DVD?
    By Anakin in forum Video Conversion
    Last Post: 4th Jun 2007, 11:52
