I was wondering if anyone new how to or what program to use to transfer avi's or mpeg's to dvd-r's to play on a dvd player. I know you can take a movie off a dvd and make them transfer into a avi or mpeg. But there has got to be a way to trasfer it back to the dvd-r so it is able to play in a dvd player. If anyone can help me, that would be great. Thanks!![]()
Graewl
Results 1 to 9 of 9
You have to start at the beginning - What is DVD
Then Convert
Then Author
all on the left side of this page.
Authoring is entirely different than ripping and burning an existing DVD.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
First you need to make DVD compatible mpegs out of your source files using one of several mpeg encoders. Lots of step by step guides in the Convert section. Skip this step if your mpeg is DVD compatible.
Then you need to author your mpegs into DVD format, guides in the Author section.
Then you need to burn your authored files to disk.
Good luck!"Art is making something out of nothing and selling it." - Frank Zappa
Zippy,
So is there a certain program I can use to author the mpeg back to DVD compatiblity? I am still a little confused on how I author it back to the DVD format. I am guessing by what you are telling me that there is a program out there that can do that. At least I hope so because I am weak on the programing area.
Ohh well. Just curious. Thanks for the help too!
Graewl
If an mpeg is not DVD compliant then it needs to be converted into an mpeg that is. TMPGEnc and several other encoders can do that.Originally Posted by graewl
Once the mpeg is dvd compliant then it can be authored. That means that the mpeg is changed into a file structure that a DVD player will accept.
Both are very different processes, but each is a step in creating a DVD. They are covered in better detail in the guides and articles over on the left hand column."Art is making something out of nothing and selling it." - Frank Zappa
http://www.avindustries.net/
they have dvd players that play avi's, mpegs, and a whole host of other video types that can be burned directly to dvd-r/rw
just put all your .avi's/mpegs directly onto the dvd then put it in and push play.
wonderful machines, soon as my $$ flow goes up a bit im getting one.
galactica,
Where did you find that out? I might have to save up some money for one of those!
If you remember where you saw the link, can you send it to me. I want to take a look at this one! Thanks! 8)
Did a search in the players section, apparently all these players support divx.
most of those players can be had quite cheap .. around £80.. except for the kiss and liteon.
The electronic components of the power part adopted a lot of Rubycons.
dvd player wont play AVI or dvd video burned discs
By rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 13:01 -
Problems with play back packard bell dvd player
By muay in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2010, 12:08 -
Would this DVD player play AVI files burnt onto a blank DVD/CD?
By jane2 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 20th Apr 2008, 19:38 -
Burning AVI file to DVD-RW to play on a Divx DVD player
By Jay8284 in forum Authoring (DVD)Replies: 4Last Post: 5th Jan 2008, 14:03 -
ac3 avi movies don't play back in 5.1 on divx dvd player
By funkyspaceman in forum AudioReplies: 6Last Post: 20th Oct 2007, 16:11
