VideoHelp.com Forum
  1. Different thread since it's a different issue - although it could be seen as being a "two steps forward, one step back" sort of issue as well.
    Anyway, I now am happily copying files off my internal HD to my external Firewire Bay with a HD tray docked in. My copy is finished, and I want to copy to my other HD tray so that I have a backup and can free up some space.
    What works so far:
    Shut XP down
    Shut drive bay off
    Replace tray
    Turn drive bay on
    Turn computer on
    What doesn't work so far:
    My first thought was to use "Safely Remove Hardware" to take the drive offline. Can't do that. XP takes the bay offline as well.
    OK, I figure, I'll replace the tray and turn it on and XP will realize I've switched things and reload the bay. Nope.
    OK, I figure, I'll turn the bay off after removal, switch the tray, and then turn on the bay followed by the tray. Nope - that seems to lock up the system.
    OK, I figure, I'll post to DVDRHelp and see if someone there can tell me what lame thing I'm doing that is causing this not to work (or how I'm misunderstanding what "Hot Swap" means in this case).
    TIA,
    Ewan
  2. 8) "hot swap" refers to the ability to remove a drive withoutshutting anything down. Normally used for raid disks. But a drive and drive enclosure must be specifically hot swappable to get this. you might need new drivers to achieve what you want. Or simply swap the drives and then goto control panel / device mgr / firewire? and refresh (f5).
    The electronic components of the power part adopted a lot of Rubycons.
  3. Член BJ_M's Avatar
    strange bay -- external firewire drives are hot swapable of course ....
    maybe you have to just pull the firewire off the back of it - then replace drive and plug it back in ..
    kinda takes the fun out of it ..
  1. Replies: 9
    Last Post: 13th Apr 2011, 09:53
  2. Problem to swap one subtitles to another
    By mangus37 in forum Subtitle
    Last Post: 2nd May 2010, 03:52
  3. Swap files, LiveCDs
    By Ai Haibara in forum Linux
    Last Post: 23rd Jun 2009, 21:50
  4. Swap out video without changing anything else on a DVD-R?
    By bizzybody in forum Authoring (DVD)
    Last Post: 24th Dec 2008, 04:07
  5. Most convinient way to swap a HDD?
    By videohalp in forum Computer
    Last Post: 27th Jun 2008, 17:24
