VideoHelp.com Forum
    Hi,
    I have a 6 part series which i would like to put onto DVD. How do i go about this please? Maybe i will end up with 2 DVD's, 3 parts on each. Each part is 45 mins.
    Do u have to create a seperate VIDEO_TS folder for each series when i burn to DVD? So if i was to fit 3 series onto a 1 DVD, 3 VIDEO_TS folders? Will that work?
    Any suggestions on this please?
    thx in advance.
  2. Member jaxxboss's Avatar
    You have a couple of options. either join the mpegs and then just add them using dvd author, or if you dont like joing mpegs due to possible audio sync probs then you can author each episode then add the bobs. That will make one file of the video ts and audio ts ready to burn.
    You never mentioned what author program you use so I just went with dvd author.
    Hi Jaxxboss, thx for replying.
    I understood everything upto the part when u mentioned the vobs, wasnt quite sure wot u meant?
    So when i have authored 3 parts of the series seperately, that would then create 3 seperate VIDEO_TS folders...then wot do u recommend after that? put all into 1 VIDEO_TS folder? then burn?
    I use TMPGEnc author.
    thx
  1. Replies: 0
    Last Post: 12th Apr 2011, 22:34
  2. Replies: 8
    Last Post: 26th Dec 2010, 17:45
  3. add subtitles for tv series
    By pcb in forum Subtitle
    Last Post: 28th Nov 2010, 16:04
  4. How do I add subtitles to a series?
    By Desman in forum Subtitle
    Last Post: 3rd Nov 2009, 03:08
  5. Add subtitles to a series DVD, not just a movie (problems with Muxman)
    By gimeis in forum Newbie / General discussions
    Last Post: 9th Sep 2008, 01:39
