VideoHelp.com Forum
  1. Just wondering, cause i have a bunch of bin/cue's i need to burn off and their only like 200 meg big. I'd like to fit 3-4 on a cd instead of wasting that extra space
  2. the finalize after burning option is grayed out.......do i just burn the 1st bin/cue file and then start a new burn session and keep the same cd in the burner and burn the 2nd bin/cue.....will this work or is it that only 1 bin/cue file per cd is the case???
  3. Member Roderz's Avatar
    No.
    you need to extract the mpg/dat files with isobuster / vcdgear then burn them togeather as vcd/svcd.
  1. cue and bin files
    By natty in forum Newbie / General discussions
    Last Post: 21st Jun 2011, 15:25
  2. How to burn a .iso/bin,cue with nero
    By Chupes in forum User guides
    Last Post: 9th Sep 2009, 20:33
  3. question how to burn bin/cue file to DVD disk
    By jimdagys in forum Newbie / General discussions
    Last Post: 17th May 2008, 11:58
  4. Having trouble with .bin/.cue files
    By UncleBose in forum Software Playing
    Last Post: 12th Jan 2008, 06:06
  5. What files/settings do I need for bin/cue
    By Choppa in forum Authoring (VCD/SVCD)
    Last Post: 23rd Jun 2007, 21:29
