i have a hp a250n pc that has the symbol with the 3 branches on it for firewire cord.this is the computer i have.
http://www.amazon.com/exec/obidos/tg...c&vi=tech-data
would you mind telling me what i need to move my camcorder/vhs tapes to my pc? thanks
piper
I believe the three branch symbol you are talking about means USB, not fire wire. Anyway, to put VHS video on your computer to use the USB port, you have several options.
-- If you have a video camera with a pass through function, you can use it to connect your VCR to your computer. Not the best captures you can get though.
-- If you purchase a hardware encoder like ADS IDVD, it will also connect to your computer's USB port and it will accept your VCR and camera RCA and S-video inputs and put them on your computer.
-- You can also purchase a video capture card, which lets you plug your VCR video directly into your computer. They start around $30, and is usually a good place to start at.
-- The pricier solutions involves analog to digital converters, which is a little box like the USB hardware endoders along with a true fire wire card, it converts your video in DV, which takes up a lot of room on your system, but gives a very good image. The two most popular ones around here are the DAC-100 and the ADVC-100.
Anyway, read the beginner's articles to get you started, as you will find most of your answers to your questions there.
Welcome to the forum, and if you do nothing else here, stay away from Tgpo. I do not trust that kid!
Hello.
no i see the spot for the usb this is above it. it looks like a y. it also says 1394 above the spot.its a circle in the middle 2 small dashes under the circle , 2 to the left and one solid square on the right side of the circle. is the dazzle connectors good?
thanks for the advice.
piper
Yes, you do have two fire wire ports.
Hello.
Trying to transfer camcorder tapes to computer via easycap *RAAAHH!*
By BostonJas in forum Video StreamingReplies: 9Last Post: 31st Aug 2010, 18:24 -
A good recorder that will transfer difficult VHS tapes?
By siberwolf in forum DVD & Blu-ray RecordersReplies: 20Last Post: 12th May 2008, 08:15 -
What I want to do: Transfer/capture old VHS and Hi8 family tapes.
By Boomer1948 in forum CapturingReplies: 7Last Post: 4th Jan 2008, 22:19 -
Transfer home movies from analog camcorder to Mac?
By cali891 in forum MacReplies: 4Last Post: 8th May 2007, 08:59 -
By cali891 in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 7th May 2007, 14:18
Statistics
Newest guides
Latest tool updates
New media comments
