VideoHelp.com Forum
Thread: PowerDVD audio
  1. May i know is there any PowerDVD plugins that increase the quality of my sound? I played a dvd file with it but the sound kinda disappointing..
  2. Mod Neophyte Super Moderator redwudz's Avatar
    I don't know of any plugins. Try the DVD on another player but I suspect the problem is with the DVD, not PowerDVD. If this is not a commercial DVD, it may have the sound encoded at a low bitrate. Check it with Gspot.
  3. Member scottb721's Avatar
    The OEM version of PowerDVD is only 2 channel. You are required to purchase the audio packs to gain various features, 1 being multi channel audio.
    To check , on the PowerDVD GUI panel click on the Cyberlink name then in the new window double click the gold POWERDVD writing.
    The audio capability is shown, either as 2 or 6
  1. PowerDVD no audio on AVCHD
    By shredcaster in forum Software Playing
    Last Post: 9th Nov 2009, 04:24
  2. PowerDVD 8 Ultra Has No Media Library for Audio
    By vhsreject in forum Software Playing
    Last Post: 12th May 2009, 08:52
  3. Outputing the audio from PowerDVD thru S/PDIF
    By maxpower2078 in forum Software Playing
    Last Post: 4th Dec 2007, 10:36
  4. No Audio on DVD-RAMs via PowerDVD XP 4.0
    By im2020 in forum Software Playing
    Last Post: 19th Jul 2007, 16:38
