Hey guys (and girls)
I know I'm late but I finally got a DVDrom drive. The first thing I would like to try is ripping a DVD but everything is so confusing. I need your opinions... what was your first guide and which one do you think is the easiest to follow? I would just like to try ripping a dvd as a test to get the hang of it. Thanks![]()
Thread: Need user opinions
Bravoxena
Depends on if your first is a DVD-5 or DVD-9
See here: http://www.dvdrhelp.com/dvdrippingThere's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
I had looked everywhere for software that fits my tastes when it comes to backing up my DVDs. I had tried almost everything and spent alot of $$ doing so. Funny after all the $$ I spent I preffer this free program that does everything in one. It really depends on what you want to do with the DVD>HD .vob files. I personally like to DVD>Decrypt>DVD2AVI>VD>AVI/Divx then burn the AVI/divx files to disks as back ups.
If you are looking to take that route I highly suggest DVX which is totally free software and is offered here:
http://www.planetdvb.net/dvx/
its a all in one type deal and the interface is much easier to follow IMO than GordianKnot (which is what many others use). Also DVX allows up to 9 pass with divx codec which many others don't! If you want to check out GordianKnot also you can find it here:
http://gknot.doom9.org/
Like I said I am not sure which route you are going with but here is another great guide for DVD ripping:
http://www.dvdrhelp.com/sefy/?id=intro.html
Hope something from this post helps.
Need Opinions On Video
By budwzr in forum EditingReplies: 0Last Post: 23rd Aug 2011, 12:18 -
pc to tv hook up need opinions
By xsfcloud in forum ComputerReplies: 6Last Post: 4th Aug 2009, 12:51 -
New user
By Ppeter in forum ffmpegX general discussionReplies: 11Last Post: 21st Mar 2009, 06:16 -
User Right
By Johnnylee_hang in forum ComputerReplies: 2Last Post: 12th Jun 2008, 03:11 -
Opinions Please
By OzarkBaby in forum Newbie / General discussionsReplies: 5Last Post: 17th Dec 2007, 15:11
Statistics
Newest guides
Latest tool updates
New media comments
