VideoHelp.com Forum
  1. Hi,
    I've checked the guides the guides but can't find my answer. I'm using PowerDVD version3.0, perhaps it's too old? I have my VIDEO_TS folder on the desktop and can't figure out how to make it play.
    When I hit play on PowerDVD it says there's no disc.
    How do I make PowerDVD look for this folder on the desktop?
    Thanks, Jerry
  2. The Mustang King arcorob's Avatar
    Locate the VOB file in explore
    RIGHT click teh file name and select OPEN WITH
    Select Power DVD. If its not listed, choose BROWSE fro PROGAMS and go to C:Program files and find POWERDVD
  3. There is a control to do this on the PowerDVD control panel. If you hover your mouse pointer over the little icons in the control panel, one of them will identify itself as being related to switching from file on disc to file on HD. I can't remember the exact wording but I remember that it was not very intuitive. But I know the function is there, I had to hunt it up myself to be able to "point" PowerDVD to some mpeg2 files on my hard disk. The non-standard interface does a good job of hiding some functions that you would think they would want to make fairly apparent.
  4. Member MOVIEGEEK's Avatar
    I think you need PowerDVD 4 or 5 to "open DVD file on hard disk drive" which uses an IFO to play.
    You could rip the disk as one long VOB using IFO mode in DVDDecrypter.
  5. Hit the button with the drive icon on it(to the left of the transport controls).
    Select "open dvd file on hard disc" , browse your way to the video TS folder and open the VIDEO_TS.IFO file. Should work then.
  1. What players can play DVD material from VIDEO_TS folder?
    By sldvd in forum Newbie / General discussions
    Last Post: 5th Aug 2011, 10:49
  2. Trying to play VIDEO_TS folder on my PS3
    By logannsan in forum Media Center PC / MediaCenters
    Last Post: 31st Mar 2010, 08:49
  3. Replies: 0
    Last Post: 29th Oct 2009, 21:29
  4. Another folder than Video_ts and Audio_ts
    By claudiofran in forum Authoring (DVD)
    Last Post: 3rd Mar 2008, 13:39
  5. No Video_TS Folder..
    By NatalieR in forum ffmpegX general discussion
    Last Post: 5th Feb 2008, 10:53
